Hey folks,
For some reason, as the title says, my secondary report wont save anywhere and it wont print either. I'm almost convinced that it isn't even being created. I've put "x"'s everywhere that a part number or confidential info is, just an FYI.
Take a look at this code from the beginning of the program:
The WeildSheet is what i want printed, and I'm declaring it here in the beginning of the program. Fast forward after the measurement routine:
Any help is appreciated.
STARTUP =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES ALIGNMENT/END MODE/MANUAL FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,MAXMIN,DEV,OUTTOL, MOVESPEED/ 500 TOUCHSPEED/ 2 SCANSPEED/500 ACCELERATION/MAXACCELX=500, MAXACCELY=500, MAXACCELZ=500 LOADPROBE/HPSX1HS_3BY50MM TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, PLACE PART IN CENTER OF TABLE WITH -A- (LONG LEG) DOWN, MAKE SURE YOU HAVE CLEARANCE FROM TOOL CHANGER! TOP OF PART IS MANUAL PLANE, INNER BORE IS MANUAL CIRCLE. PROGRAM USES HPSX1HS_3BY50MM AND HPSX1HS_5BY_50_90DEG PROBES WORKPLANE/ZPLUS C1 =COMMENT/INPUT,YES,FULL SCREEN=NO, Inspectors Initials C2 =COMMENT/INPUT,YES,FULL SCREEN=NO, Finish S/N C4 =COMMENT/INPUT,NO,FULL SCREEN=NO, Forging S/N C5 =COMMENT/INPUT,NO,FULL SCREEN=NO, Forging Heat Code C6 =COMMENT/INPUT,NO,FULL SCREEN=NO, Machine Operator ASSIGN/PNAM=GETTEXT("Part Name",0,"FILEHEDR") ASSIGN/REVNO=GETTEXT("Revision Number",0,"FILEHEDR") ASSIGN/OPNO=GETTEXT("Serial Number",0,"FILEHEDR") ASSIGN/STNO=GETTEXT("Statistics Count",0,"FILEHEDR") ASSIGN/PROGNAM=PNAM S_N =LABEL/ IF_GOTO/C2.INPUT==0,GOTO = S_N TRACEFIELD/NO_DISPLAY,LIMIT=15 ; Serial : C2.INPUT TRACEFIELD/NO_DISPLAY,LIMIT=15 ; Operator : C1.INPUT ASSIGN/SERN=C2.INPUT ASSIGN/PATH="J:\PCDMIS Reports\XXXXXXXXXXX\\" ASSIGN/MYFILENAME=PROGNAM + "_" + SERN ASSIGN/MYFILENAME=PATH + MYFILENAME + ".RTF" [B]ASSIGN/WEILDSHEET="J:\PCDMIS Reports\XXXXXXXX\\"+"XXX_Weld"+"_"+SERN+".RTF"[/B] C3 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, DO YOU WANT TO RUN SETUP? Note: (Must run setup if this is the 1st part ran or part has been moved.) IF_GOTO/C3.INPUT=="YES",GOTO = SETUP GOTO/PROG SETUP =LABEL/
EXTERNALCOMMAND/NO_DISPLAY, NO_WAIT ; C:\DILLON CMM FILES\DATAPAGE\DATAPAGESTATS.EXE PRINT/REPORT,EXEC MODE=END,$ TO_FILE=ON,OVERWRITE=MYFILENAME,AUTO OPEN REPORT=OFF,$ TO_PRINTER=ON,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=OVERWRITE,FILENAME= ,$ REPORT_THEORETICALS=ALL,REPORT_FEATURE_WITH_DIMENS IONS=NO,$ TO_EXCEL_OUTPUT=OFF, PREVIOUS_RUNS=DELETE_INSTANCES ASSIGN/MYDATE=SYSTEMDATE("MM/dd/yyyy") CS2 =REPORT/CUSTOM, FILENAME=XXXX_Weld_Sheet, Section=-1 PARAM/TEXT_1.TEXT=C2.INPUT PARAM/TEXT_2.TEXT="*"+C2.INPUT+"*" PARAM/TEXT_3.TEXT=C4.INPUT PARAM/TEXT_4.TEXT="*"+C4.INPUT+"*" PARAM/TEXT_5.TEXT=C5.INPUT PARAM/TEXT_6.TEXT="*"+C5.INPUT+"*" PARAM/TEXT_7.TEXT="XXXXXXXXX" PARAM/TEXT_8.TEXT="*"+"XXXXXXXX"+"*" PARAM/TEXT_9.TEXT="XXXXXXXXX" PARAM/TEXT_10.TEXT="*"+"XXXXXXXXXXX"+"*" PARAM/TEXT_11.TEXT=CIR_34_492_OD.DIAM PARAM/TEXT_12.TEXT="*"+CIR_34_492_OD.DIAM+"*" PARAM/TEXT_13.TEXT=V1 PARAM/TEXT_14.TEXT="*"+V1+"*" PARAM/TEXT_15.TEXT=V5 PARAM/TEXT_16.TEXT="*"+V5+"*" PARAM/TEXT_17.TEXT="FULL" PARAM/TEXT_18.TEXT="*"+"FULL"+"*" PARAM/TEXT_19.TEXT=C6.INPUT PARAM/BARCODEWIZ1.BARCODE=C2.INPUT+",XXXXXXXXXX,"+C4.INPUT+",XXXXXXXXXX,"+C5.INPUT+",FULL" PARAM/= ENDCUSTOM/ PRINT/REPORT,EXEC MODE=END,$ TO_FILE=ON,OVERWRITE=WEILDSHEET,AUTO OPEN REPORT=OFF,$ TO_PRINTER=ON,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMEN SIONS=NO,$ TO_EXCEL_OUTPUT=OFF, PREVIOUS_RUNS=DELETE_INSTANCES
