Displaying deviation from CAD
  • Displaying deviation from CAD
    I work with die casting now and starting to use CAD models. I want to be able to show the deviations of features on the graphics display vs CAD model. Is it possible to have arrows or something show the deviation angles, vectors, etc.?
    I'm using v4.1 (Yes, I have to. Don't have authority to upgrade)
    DIMINFO boxes will display on the graphics screen, is that what you are looking for?
      I want to be able to display arrows or indicators to show which way features need to be moved on startups instead of trying to explain which way is x, y, z, etc. People here are not used to the reports so looking into alternative graphical representations.
        The easiest way I have found is to rotate the CAD axis to match the machining center axis before dimensioning the features. That way all the deviations on the report match the offset of the machine tool.
        Kevin
          Edit - preferences - setup under the general tab check the box Show hit deviations
          I think this is what you are looking for
          "People demand freedom of speech as a compensation for the freedom of thought, which they seldom use." ~ Soren Kierkegaard
            Any way to adjust the arrow size? They are tiny.
              Does the MULT=1.00 change the size of the arrow (in the dimension line)?
                highlight show hit deviations and change the deviation arrow multiplier to 3 or 4 this will change the size of the arrows
                  Ok guys, found it. I went into the dimension and turned on graphical analysis and turned up the multiplier. It shows my deviation directions from nominals.
                  Case closed!
                    Case closed!
                    RESOLVED
                    Hack away
                      Matt how bout a larger picture of your fan club’s home page I cant quite make out the links
                        under settings editor open GL settings Draw Arrow as Solid- enter value
