Using Variables
  • Using Variables
    Hello,
    I'm very new to using using variables and would like to ask how I would develop a measurement using a plane I have created and subtracting the nominal/print radius of .0787. I do measure the radius and report that as a separate dimension, but I also need to report the distance from the plane created and the nominal radius. Be easy on me guys..
    Thanks!
    As far as the variables go...
    Create a generic point. The point's Z height is driven by the MEASURED ACTUAL Z height of PLN1 with your value subtracted. Report the Z height of the point.
    The above being said, PC DMIS can do the distance from a plane to a radius. In the DIST dialogue box, there are options for ADD RADIUS, SUBTRACT RADIUS, CENTER TO CENTER
    PLN1 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR
    THEO/<0,0,0>,<0,0,1>
    ACTL/<0,0,0>,<0,0,1>
    TARG/<0,0,0>,<0,0,1>
    ANGLE VEC=<1,0,0>,RADIAL
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=NO
    CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0,0>,<1,0,0>,2.555
    ACTL/<0,0,0>,<1,0,0>,2.555
    TARG/<0,0,0>,<1,0,0>
    START ANG=0,END ANG=360
    ANGLE VEC=<0,1,0>
    DIRECTION=CCW
    F1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$
    NOM/XYZ,<0,0,PLN1.Z-0.0787>,$
    MEAS/XYZ,<0,0,PLN1.Z-0.0787>,$
    NOM/IJK,<0,0,1>,$
    MEAS/IJK,<0,0,1>
    DIM LOC1= LOCATION OF POINT F1 UNITS=IN ,$
    Z -0.0787 0.0020 0.0020 -0.0787 0.0000 0.0000 ----#----
    END OF DIMENSION LOC1
    DIM DIST1= 2D DISTANCE FROM PLANE PLN1 TO CIRCLE CIR1 (CENTER TO CENTER),ADD_RADIUS UNITS=IN,$
    M 1.2775 0.0004 0.0004 1.2775 0.0000 0.0000 ----#--
    This is some basic info to get you going, if you need more help don't hesitate to ask.
      Thanks for the response Dan! I really appreciate it. I'm horrible at describing things, but what I'm asked to do is take the measured value from the plane to the center of the radius and force that measurement to subtract .0787 regardless of what the radius actually checks.
      Thanks again!
        Thanks again!
        Are you able to post a picture of what you need?
        Otherwise, you would need to do something like this:
        ASSIGN/V1=PLN1.X-0.0787
        NOM/XYZ,<PLN1.TX-0.0787,0,0>,$
        MEAS/XYZ,<V1,0,0>,$
        NOM/IJK,<0,0,1>,$
        MEAS/IJK,<0,0,1>
        Then dimension F1.
          Thanks again!
          No problem, I understand that one a lot better, how about this?
          1) measure plane
          2) measure circle
          3) create a generic point that you force to be the ACTUAL center of the circle minus 0.0787 in the Z.
          4) distance dimension...generic point to the plane
          Please notice that I used a Y workplane (since we're working with a 2d feature).
          WORKPLANE/YMINUS
          THEO/<0,0,-0.5>,<0,1,0>,2
          ACTL/<0,0,-0.5>,<0,1,0>,2
          TARG/<0,0,-0.5>,<0,1,0>
          ANGLE VEC=<1,0,0>
          DIRECTION=CCW
          NOM/XYZ,<CIR1.X,CIR1.Y,CIR1.Z-0.0787>,$
          MEAS/XYZ,<CIR1.X,CIR1.Y,CIR1.Z-0.0787>,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>
          DIM DIST1= 2D DISTANCE FROM PLANE PLN1 TO POINT F1 PAR TO ZAXIS,NO_RADIUS UNITS=IN,$
          M 0.5787 0.5787 0.1000 0.1000 0.0000 0.0000 ----#----
            Thanks for the responses guys!! Dan, that worked. Again, I appreciate it!!
              Happy to help!
