2019 r2 sp10
  • 2019 r2 sp10
    https://www.wilcoxassoc.com/public/P...9_R2/SP10/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...9_R2/SP10/x64/
    Release Notes - 2019 R2 SP10
    • PCD-149154 - You can now see PC-DMIS correctly transforms the probe
    position when you transform a CAD model and compute the deviation from
    CAD (T) in the Probe Readout window.
    • PCD-162303 - You no longer get an application error when you edit a form
    report that contains an error in the VB script.
    • PCD-185414 - You can now see the correct theoretical values for a
    constructed 3D width.
    • PCD-196206 - PC-DMIS no longer sends incorrect error events when you
    enable the Find Hole option for auto features.
    • PCD-205779 - You no longer get an application error when you changed a
    nominal value in the Edit window on a constructed line.
    • PCD-207984 - You can now see the correct default options for graph, text,
    and output of the Thickness Gage feature's internal 3D distance dimension.
    • PCD-207985 - PC-DMIS now correctly calculates the nominal for thickness
    gage dimensions.
    • PCD-208067 - You no longer get an application error when you save a
    measurement routine that contains an image capture command.
    • PCD-208631 - PC-DMIS no longer sets the Thickness Gage internal location
    dimension options to their default values after you execute the measurement
    routine.
    • PCD-210608 - You no longer get an application error when you switch
    between active measurement routines.
    • PCD-210652 - You no longer get an application error when you close a
    measurement routine that contains vision features.
    • PCD-210681 - You no longer get an application error when there is a license
    failure.
