Is there somewhere I can tweak this so I can get the last 1/4 inch of z-axis travel in my measuring envelop? Always pisses me off when I get a job set up only to find out I need another mouse turd of axis travel to measure the **** thing.
Machine Parameters
Probably not. Some of the older machines you could tweak and get a little, but I doubt any machine made in the last 20 years can be tweaked. Is it a clearance problem (bridge won't clear) or are you out of 'range'? If out of range, can you use a different probe angle or make a 'custom' tip? I have had parts that were 8" longer than the Y travel of hte machine (longest axis of the machine) and I was able to measure it all by using a partial star-probe and a 75,0 and 75,-180 probe angle (with the partial star tip pointing almost down at those angles).sigpic
Put in a longer probe buildup. I wish I had that problem. With just the PH9 in the Z-column, the head itself will touch my table, so with ANY probe in it, I can more than reach the table.sigpic
that's the Table avoidance buffer. you can adjust it. (snicker, he-he)
http://re3.mm-a7.yimg.com/image/3732789422sigpic
Originally posted by Cumofo View Postthat's the Table avoidance buffer. you can adjust it. (snicker, he-he)
B&S Global 544
Using 3.7mr3
Peace
Greg
Originally posted by gcunniff View PostI'm using a 90>90 tip to check a bore, so a long tip isn't going to help me. How do you adjust the table avoidance buffer??
How deep are you going in the bore? Can you use a 82.5,90 tip?sigpic
2.4" into a 0.987" dia. bore. I could change the tip angle, but then I wouldn't be able to sample points all the way around the diameter.
Normally, I'd just use a couple 123 blocks and redo the setup, but this is the 2nd job this week where I've run out of room and it's beginning to chap my buttocks....
Originally posted by Goodluck View PostYou know, I always like to put my parts up on a block high enough that when at my lowest Z in the program if the probe were to be 'accidentally'rotated to A0B0 the probe (the TP20 I don't care so much about the tip) can't contact the table.
That is a VERY good point.
Originally posted by gcunniff View Post2.4" into a 0.987" dia. bore. I could change the tip angle, but then I wouldn't be able to sample points all the way around the diameter.
I would suggest...
anyone else?sigpic
lol....I'll have to look into that.
I have a total z-axis travel of 17.978". with the head at a 90>90 tip, I have approximately 1" between the bottom of the PH10M and the plate, when I run the axis out to its limit. When I set this job up to check it, the bottom of the bore is actually at around 1.1". So I still have some distance to go when I manually drive the machine, but when I go into DCC I get the machine out of parameter limits.
AH-HA!
Lower your PREHIT and RETRACT values OR put in a check distance value. Without a check distance value in the program (I never use it) Pcdmis will want to be able to travel BEYOND the nominal hit position by the prehit and retract values. The other option is to change the start/end angles of the circle you are checking so that it does not want to take a hit in the straight-down direction.sigpic
by ClayOgreSome time ago, I wrote a program for a V8 engine block on the LK-G80 that is "my" CMM. The CMM it was intended to run on is a larger machine,...
09-18-2014, 11:59 AM -
If your certificate of calibration states that your volumetric accuracy is .0006 inch, do any of you assume that if you only use for example one half...
04-03-2006, 06:16 PM -
by josephday76Wasn't really sure which topic to post this in as it's not a PC-DMIS question but more a mechanical issue.
Have a look at the pictures...-
03-09-2012, 09:57 AM -
by Lee JohnsonOne of the guys here in another lab, came to me last night and said that when he homed his machine it drove it into the table and took out a TP 200. ...
10-27-2011, 03:08 PM -
by AlexADoes anybody run a warm up cycle if the machine hasn't been used for a couple of days or even a day?
We seem to be having issues with the...-
05-06-2014, 10:19 AM -
