Hi Everyone!
I am working with a forge part with no datum structure. It is calling for a profile of .120 u .09 to itself. (+.09/-.03).
My though is that the simplest way to approach this is with an iterative alignment (machine to part), then go to town with auto feature vector points (or would it best to use measure point and why?). And do a best fit alignment of all and only the profile point then dimension it.
I am working offline. I see the deviations when dimensioning which and should be at zero. So what I am gathering is my alignment needs adjusting?
Q:
Thank you for taking the time !!!
neil.challinor
Q:
- It won’t let me upload a picture it is prompting me this message "Upload failed due to your usergroup's upload quota. This file will require 50.2 KB but you only have 17.1 kb of 1.50 MB remaining". How do fix this so I may upload a snip.
- Will I get arcuate results?
- How would I double check myself?
- What are the cons of using a read-point for an iterative alignment? I love the idea of removing the manual probing completely. But is it and will it be aureate?
READ POINT =FEAT/POINT,CARTESIAN THEO/<24.81,-2.56,3.11>,<0,0,1> ACTL/<35.41,-19.35,20.98>,<0,0,1> READPOINT/ A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/TRANS,XAXIS, ALIGNMENT/TRANS,YAXIS, ALIGNMENT/TRANS,ZAXIS, ALIGNMENT/TRANS,XAXIS,READ POINT ALIGNMENT/TRANS,YAXIS,READ POINT ALIGNMENT/TRANS,ZAXIS,READ POINT ALIGNMENT/END PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<0.02,0.22,-0.2>,<-0.0756796,-0.7370436,0.6715946> ACTL/<0.02,0.22,-0.2>,<-0.0756796,-0.7370436,0.6715946> TARG/<0.02,0.22,-0.2>,<-0.0756796,-0.7370436,0.6715946> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/TRANS,XAXIS,PNT3 ALIGNMENT/TRANS,YAXIS,PNT3 ALIGNMENT/TRANS,ZAXIS,PNT3 ALIGNMENT/END PNT1 =FEAT/POINT,CARTESIAN THEO/<-0.1,0.54,0.12>,<-0.1119777,0,0.9937107> ACTL/<-0.1,0.54,0.12>,<-0.1119777,0,0.9937107> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<-0.1,0.54,0.12>,<-0.1119777,0,0.9937107>,<-0.1,0.54,0.12>,USE THEO=YES ENDMEAS/ PNT2 =FEAT/POINT,CARTESIAN THEO/<-0.79,1.59,0.04>,<-0.1119777,0,0.9937107> ACTL/<-0.79,1.59,0.04>,<-0.1119777,0,0.9937107> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<-0.79,1.59,0.04>,<-0.1119777,0,0.9937107>,<-0.79,1.59,0.04>,USE THEO=YES ENDMEAS/ PNT4 =FEAT/POINT,CARTESIAN THEO/<-0.46,2.98,0.08>,<-0.1119777,0,0.9937107> ACTL/<-0.46,2.98,0.08>,<-0.1119777,0,0.9937107> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<-0.46,2.98,0.08>,<-0.1119777,0,0.9937107>,<-0.46,2.98,0.08>,USE THEO=YES ENDMEAS/ PNT5 =FEAT/POINT,CARTESIAN THEO/<-0.92,4.27,0.03>,<-0.1119777,0,0.9937107> ACTL/<-0.92,4.27,0.03>,<-0.1119777,0,0.9937107> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<-0.92,4.27,0.03>,<-0.1119777,0,0.9937107>,<-0.92,4.27,0.03>,USE THEO=YES ENDMEAS/ MOVE/POINT,NORMAL,<-0.38,3.02,0.39> MOVE/POINT,NORMAL,<-0.08,2.89,0.36> MOVE/POINT,NORMAL,<0.17,2.83,0.16> PNT6 =FEAT/POINT,CARTESIAN THEO/<0.01,2.59,-0.19>,<0.9531094,0.1915064,0.2343242> ACTL/<0.01,2.59,-0.19>,<0.9531094,0.1915064,0.2343242> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<0.01,2.59,-0.19>,<0.9531094,0.1915064,0.2343242>,<0.01,2.59,-0.19>,USE THEO=YES ENDMEAS/ PNT7 =FEAT/POINT,CARTESIAN THEO/<0.28,0.72,-0.17>,<0.9767192,0.0946515,0.1925116> ACTL/<0.28,0.72,-0.17>,<0.9767192,0.0946515,0.1925116> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<0.28,0.72,-0.17>,<0.9767192,0.0946515,0.1925116>,<0.28,0.72,-0.17>,USE THEO=YES ENDMEAS/ MOVE/POINT,NORMAL,<0.61,0.04,-0.19> MOVE/POINT,NORMAL,<0.58,-0.13,-0.28> MOVE/POINT,NORMAL,<0.5,-0.25,-0.33> MOVE/POINT,NORMAL,<0.29,-0.39,-0.42> PNT8 =FEAT/POINT,CARTESIAN THEO/<0.04,-0.11,-0.46>,<0,-1,0> ACTL/<0.04,-0.11,-0.46>,<0,-1,0> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<0.04,-0.11,-0.46>,<0,-1,0>,<0.04,-0.11,-0.46>,USE THEO=YES MOVE/POINT,NORMAL,<0.04,-0.4,-0.46> ENDMEAS/ MOVE/POINT,NORMAL,<0.01,-0.37,-0.06> MOVE/POINT,NORMAL,<-0.08,-0.16,0.25> MOVE/POINT,NORMAL,<-0.04,0.13,0.41> A3 =ALIGNMENT/START,RECALL:A2,LIST=YES ALIGNMENT/ITERATE PNT TARGET RAD=0.05,START LABEL=,FIXTURE TOL=0,ERROR LABEL= MEAS ALL FEAT=ALWAYS,MAX ITERATIONS=5,LEVEL AXIS=ZAXIS,ROTATE AXIS=XAXIS,ORIGIN AXIS=YAXIS LEVEL=PNT1,PNT2,PNT3,PNT4,, ROTATE=PNT5,PNT6,, ORIGIN=PNT8,, ALIGNMENT/END PNT_1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-0.21,0.98,0.11>,<-0.1119777,0,0.9937107> ACTL/<-0.21,0.98,0.11>,<-0.1119777,0,0.9937107> TARG/<-0.21,0.98,0.11>,<-0.1119777,0,0.9937107> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO MOVE/POINT,NORMAL,<-0.34,0.5,0.38> MOVE/POINT,NORMAL,<-0.55,0.4,0.23> MOVE/POINT,NORMAL,<-0.64,0.36,0.03> PNT_2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-0.34,0.28,-0.41>,<-0.9921095,-0.1249404,0.0104189> ACTL/<-0.34,0.28,-0.41>,<-0.9921095,-0.1249404,0.0104189> TARG/<-0.34,0.28,-0.41>,<-0.9921095,-0.1249404,0.0104189> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO PNT_3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-0.3,0.12,-1.64>,<-0.9302715,-0.3668206,-0.0061264> ACTL/<-0.3,0.12,-1.64>,<-0.9302715,-0.3668206,-0.0061264> TARG/<-0.3,0.12,-1.64>,<-0.9302715,-0.3668206,-0.0061264> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO MOVE/POINT,NORMAL,<-0.67,0.33,-1.2> MOVE/POINT,NORMAL,<-0.72,0.44,-1.12> PNT_4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-0.51,0.65,-1.16>,<-0.7020729,-0.6942352,0.1585279> ACTL/<-0.51,0.65,-1.16>,<-0.7020729,-0.6942352,0.1585279> TARG/<-0.51,0.65,-1.16>,<-0.7020729,-0.6942352,0.1585279> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO MOVE/POINT,NORMAL,<-1.08,0.51,-1.18> MOVE/POINT,NORMAL,<-1.25,0.6,-1.19> MOVE/POINT,NORMAL,<-1.4,0.79,-1.25> MOVE/POINT,NORMAL,<-1.43,0.92,-1.36> PNT_5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-1.16,1.04,-1.78>,<-0.9965702,-0.0560934,0.0608383> ACTL/<-1.16,1.04,-1.78>,<-0.9965702,-0.0560934,0.0608383> TARG/<-1.16,1.04,-1.78>,<-0.9965702,-0.0560934,0.0608383> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO PNT_6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<-1.19,1.32,-0.43>,<-0.9986704,-0.0483447,0.0178954> ACTL/<-1.19,1.32,-0.43>,<-0.9986704,-0.0483447,0.0178954> TARG/<-1.19,1.32,-0.43>,<-0.9986704,-0.0483447,0.0178954> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=0.2 SHOW HITS=NO A4 =ALIGNMENT/START,RECALL:A3,LIST=YES ALIGNMENT/BF3D,LEAST_SQR,CREATE WEIGHTS=NO,ROTANDTRANS,USE SCALING=NO,0,0,0,0.02,-0.03,0 ITERATEANDREPIERCECAD=YES,TOLERANCE=1000,MAX ITERATIONS=100 Deviation Threshold=0.0003937 SHOWALLINPUTS=NO,SHOWALLPARAMS=NO ALIGNMENT/END $$ NO, [email protected] DIMENSIONS @! DISPLAYPRECISION/4 DIM PRFL_1= LOCATION OF POINT PNT_1 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 -0.0014 -0.0014 0.0000 --#--------- END OF DIMENSION PRFL_1 ASSIGN/V1=PRFL_1.T.OUTTOL IF/V1<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC1 IS OUT BY "+V1+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/ DIM PRFL_2= LOCATION OF POINT PNT_2 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 0.0003 0.0003 0.0000 ---#-------- END OF DIMENSION PRFL_2 ASSIGN/V2=PRFL_2.T.OUTTOL IF/V2<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC2 IS OUT BY "+V2+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/ DIM PRFL_3= LOCATION OF POINT PNT_3 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 0.0005 0.0005 0.0000 ---#-------- END OF DIMENSION PRFL_3 ASSIGN/V3=PRFL_3.T.OUTTOL IF/V3<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC3 IS OUT BY "+V3+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/ DIM PRFL_4= LOCATION OF POINT PNT_4 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 0.0005 0.0005 0.0000 ---#-------- END OF DIMENSION PRFL_4 ASSIGN/V4=PRFL_4.T.OUTTOL IF/V4<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC4 IS OUT BY "+V4+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/ DIM LOC5= LOCATION OF POINT PNT_5 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 -0.0002 -0.0002 0.0000 --#--------- END OF DIMENSION LOC5 ASSIGN/V5=LOC5.T.OUTTOL IF/V5<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC5 IS OUT BY "+V5+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/ DIM PRFL_6= LOCATION OF POINT PNT_6 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL T 0.0000 0.0900 0.0300 -0.0002 -0.0002 0.0000 --#--------- END OF DIMENSION PRFL_6 ASSIGN/V6=PRFL_6.T.OUTTOL IF/V6<>0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, ! ERROR ! "PROFILE LOC6 IS OUT BY "+V6+"" --- PLEASE CANCEL AND INFORM SUPER/PROGRAMER AND DON'T CONTINUE END_IF/
neil.challinor
