Haven't used CAD much. Need help measuring CAD model. Do I need to create alignments first? Also, my probe seems to be in the wrong vector when measuring features.
Measuring CAD model
Try...
THIS
I do my iterative alignments to non-datum features just to locate the part to the machine. Then I do a regular alignment to my print datums.Last edited by JamesMannes; 05-24-2007, 10:54 AM.sigpic
Measuring cad-2
1. no you dont have to do alignments if all you are doing is measuring a few features on the cad model. If you are programming off the cad model for a future run...yes.
2. the probe orientation to the cad model probably isnt correct because the coordinate system of the cad model isnt oriented the way you want it. For this you have a few options, 1. have the cad department orient the model the way you want it, 2 use the machine-cad setup (F5). and if you are running 4.0 or higher, you can change the coordinate system the way you want it.
Timsigpic
Ok looks like I have to use alignments per print to find basic dimensions I want. My probe vector was wrong cuz I did not rotate my angles to match x,y,z like I would in real measuring.I used to be high on life but I built up a tolerance.
by NasejhmoobI need help on how to best approach this...I have a finish print with a finish CAD model, but I am to program it to the rough state. When I align everything...
03-23-2017, 04:21 AM -
by UnderspecI don't know if it's monday or what but I can't seem to snap this cad model to my alignment without doing a CAD=Part. I've taken points on the CAD, ran...
07-09-2007, 01:27 PM -
by c_beardenI have written an offline program and I'm running it offline....the probe is offset by a large distance from the CAD MODEL and does not contact the CAD...
11-08-2010, 11:34 AM -
by DarrollhI have just been given a print without a CAD model. What CAD software would you guys recommend?
06-22-2017, 09:18 AM -
by hitalovI was programin using the actual part, but i find out that there in a CadModel for it,
is there any way to add the MODEL and do PART=CAD aligment...-
04-09-2015, 02:56 PM -
