When you dimension True Position under Axes the Auto box is checked by default (this will result in all 3 axis being displayed). Just check the two axis you wish to use. Or just dimension it with Auto checked and delete the one axis you don't want (highlight the line with the axis you wish to remove and hit delete).
As far as Pep to center goes I would say it depends upon what you are trying to check. Personally I don't use it. Here's what DMIS says:
"Deviation Perpendicular to Centerline
The Deviation Perpto Centerline check box determines whether PC-DMIS calculates the deviation perpendicular to the feature's theoretical centerline or if the deviation is calculated perpendicular to the direct X, Y, and Z values.
If selected, PC-DMIS calculates the deviation perpendicular to the feature's theoretical centerline, ignoring any deviation in the direction of the centerline.
If deselected, PC-DMIS calculates the deviation perpendicular to the X, Y, and Z values.
This check box is especially useful with sheetmetal points which may have approach vectors not oriented along the X, Y, or Z axis. This check box will allow the deviation to be found perpendicular to the approach vector."
I am trying to calculate the true position on a hole in a sheet metal part. The surface vector of the hole is 0,0,1. I am using the perp to centerline...
Was wondering if all three axes are selected for a true position if PCDMIS will correctly compute the deviation for all three axes for the result? The...
