Xact measure should utilize the pcdmis size function when evaluating for datum shift instead of what appears to be l^2.
When measuring a casting that had an as cast datum id diameter that was 4.4300 +/- .020, the acutal measured feature was out of round and measured +.0218 and -.0235 on size, but when using the xact measure it calculated an l^2 (least squares) at 4.4286 allowing for .0186 datum shift. When the datum mating evelope is less than the lowest possible size you do not get datum shift. This error needs to be fixed in order to follow asme y14.5.
Has anyone else witnessed this or know if exact measure does in fact use l^2?
