Help....Datum Error
  • Help....Datum Error
    I just crashed our CMM and now have a limp probe head and "datum error" light on the probe head controller display.
    What do I need to do to reset it? I tried rebooting but that didn't work.
    The controller is a PHC10
    Probe head is a PH10MQ with a TP20
    Press the E-stop button
    Un fix the E-stop button
    press machine start
    clear probe and:
    A) Restart program
    B) Re-calibrate probe
    C) check that program 4 why it crash?
    http://re3.mm-da.yimg.com/image/1660088086
    The Force is strong with this one.
    G
      That didn't work....still no light on the probe head and datum error light came back.
      Did I kill it?
        I see that you rebooted. Did you shut the machine and the computer completely down? If so, I believe you are DOA. How did the crash unfold? Did the actual head hit you're part(not the probe head on), or the probe from the side or other angle? Probably DOA. Brown and Sharpe has a RBE program (Repair By Exchange). 1-800-343-7933. Sorry for you're loss.
          you need to shut off the power to the controller if it is seperate from the machine
          if you have a HCU1 manual probe positioner...you need to hit the reset on it
          if this still does not help.....do as James said....call for help
          Starrett RGDC 4028-24 :alien:
            Yep, computer, machine controller and probe head controller were all powered down and then back up.
            It was a direct hit, straight on .....with a little speed
              Did you say what brand and model CMM you have?
                Make sure the auto joint adaptor didn't come loose in the crash try tightening the screw at the back of it.
                To the Brave and the Faithful nothing is impossible
                  Brown and sharpe Excel 9-15-9
                    Do you have a Renishaw HCUI box that shows the probe angle. Can you manually make the head move by hitting the A/B +/- buttons. Should reset the head.
                      It doesn't do anything when I hit the buttons.
                      The red error light is also lit on it also.
                        reset button on probe controler?
                        B&S Global 544
                        Using 3.7mr3
                        Peace
                        Greg
                          1-800-343-7933....tech support. You might be SOL.........sorry
                            Sounds like the Pulse Width Modulator Card is kaput, your service engineer should have it changed in 15 minutes.
                              http://re3.mm-a6.yimg.com/image/3553105507
                              Scotty...I've got...to get...
                              the pulse, width, modulator, changed.
                              http://re3.mm-a3.yimg.com/image/2696391419
                              Aye Capn' But the equipment
                              she can't take anymore.
                              http://re3.mm-a6.yimg.com/image/3558323218
                              **** it Jim, he's an engineer,
                              not a magician.
