I was hoping to get some help on this. See image below from the Standard. As far as I know, PC-DMIS cannot do this as per the callout since the holes are different sizes.
The closest workaround I can come up with is to dimension Coaxiality of one cylinder to the other, but you need to assign one of them as the datum axis (second selected feature) when using coaxiality. The callout doesn’t specify which is the “datum” axis when comparing one to the other.
I searched recent posts but was unable to find a clear answer. My question is: does PC-DMIS support this specific callout? If not, what is the best workaround? Coaxial Position.jpghttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
