I like this one.
It is a machined aluminum piece, approx 1 X 2 X 1.5 inches. Hollow.
When I get it, it is still attached on the side so I have someting to hold on to.
There are no datums specified.
The only flat features are the mounting surface on the face and a small area on the bottom (green on the left and right view).
The top has a surface at 16° to the face and a small hole that is dimensioned to the face and bottom surfaces.
Clear?
I plan to level to the face, rotate to a couple points or a line on the bottom and then translate these features plus either the hole at the top or the hole at the back.
For dimensioning the hole at the top I plan to use a pierce point to a plane at the top. Tolerance is ± .001.
There are some other features to measure, but much looser tolerances.
I am using an iges, and of course all axis need to be changed.
Does all this sound plausible?
Clear?
