Is there a way for pcdmis to not ask if i want to move cursor to end of the program when enabling program mode....alt-F4 or better yet to just stay in program mode even if i execute a block of code using ctrl + L? I am programming offline.
Program Mode
Originally posted by MrMatt68 View PostIs there a way for pcdmis to not ask if i want to move cursor to end of the program when enabling program mode....alt-F4 or better yet to just stay in program mode even if i execute a block of code using ctrl + L? I am programming offline.
There MIGHT be a registry setting you could turn off to stop that from popping up but I'm pretty sure that message is embedded within the software and when you updated to a new version of PCD (IF we figured out how to do this) you'd have to remember to keep doing it.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
Originally posted by MetsoMetrology View PostI found the entry in the settings editor. Its under Option and then "WarnCursorNotAtEOF", but I can't get it to work. I put 0 in as the value (default is 1) but no luckSF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
Originally posted by DAN_M View Post
Its nice to:
-Make a plane with weird hit patterns
-Drag your probe across the screen to make movepoints
(1) I almost never get cad files of the fixtures, and the rare cases where I do get one, the physical fixture doesn't match. It might be close, but not close enough to trust offline programming around
(2) Since I 'never' get fixture cad files, I can't really program a part until I have the fixture
So, unless I get the fixture and the parts at the same time, I set up the fixture, make the alignment program, then map out the clamps, gates, etc., that would be in the way of checking the part. I can then 'sort of' program offline, sort of. I generate all the points and such, missing the obstacles (SPC, MATING SURFACE, NON-MATING SURFACE, TRIM, HOLES, SLOTS, in that order!), save that as a 'point order' file (for creating Datapage variable sets), then I start putting it into an 'intelligent' check order, 'dry running' around all the stuff on the fixture.
Sheet metal is a whole different world from 'chunk' parts, let me tell you.Last edited by Matthew D. Hoedeman; 01-28-2021, 11:15 AM.sigpic
I use a macro on my 3-D mouse to have it go into program mode and automatically answer no when the assigned button is pressed.
- 2 likes
Originally posted by cdesmarest View PostI use a macro on my 3-D mouse to have it go into program mode and automatically answer no when the assigned button is pressed.
I have the standard 3d Connexion mouse (small circular one) and love itSF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
I have always wanted to try one of those. Are they worth it?
- 1 like
by inspector212I'm missing something here.
I'm updating a program to a new model offline and changing all the move points. I "Ctrl+E" the move...-
08-12-2009, 10:30 AM -
Hey I am new with dmis and just recently I have started noticing that when I execute just a highlighted section and I run "execute block" when...
04-19-2007, 11:34 PM -
by TestedDoes any one know of a code to change a program from online mode to offline mode?
Thank you all.
It looks like "slesholdofthreep"...-
07-24-2007, 12:07 PM -
Looking for some benefits of offline programming that I can present to the bean counters.
what I have so far is:
- Program...-
12-23-2014, 08:23 AM -
by d.evansI have a program that I wrote a while back, but right now I don't have an actual part to measure with it. How can I execute the program without the part...
02-23-2015, 11:58 AM -
