Hi All,
We downloaded 4.2 last week and have been running test when time permits. We've noticed a few surprises and wondered is anyone else is encountering the same problems.
First, when measuring a stud with a surface sample, there is a move before the first sample hit of 100-200 mm. This condition does not happen on every stud, but enough to keep you awake. Second, the starting and ending angles on studs have randomly changed as well forcing you to partially re program your part. Haven't notice this on any holes, just studs. Third, when measuring certain round slots, PcDmis will cough up an error that states it "cannot create best fit for this feature", yet when using F9 on the feature and re measuring, all is fine.
The programs we normally run take approx one hour to run, so needlessly to say, we do not have time to reprogram a boat load of features just to upgrade to 4.2. For now, we are sticking with 3.7mr3 until there is a MR or new version released.
We are running a Dea Vento with a Dea controller, P4 with 1gb of ram, XPsp2 pro.
Maybe 4.2 will give different results depending on the type of controller.
