I have a model with several subassy's. none of the subassy's have the same origin as the main part. Does anyone else have this problem and how do you deal with it.
Working with models
Originally posted by calbritton View PostI have a model with several subassy's. none of the subassy's have the same origin as the main part. Does anyone else have this problem and how do you deal with it.sigpic
Then you are ready to check them all in relationship to the assembly. You do NOT need an XYZ zero point on a model (or part) to check it. You simply check it to the datums called out and the values of those datums, no matter what they might be.sigpic
I'm trying to check a roughed out part to finished model. I have to make sure that there is enough material around the part for finishing operation. ...
Channel: PC-DMIS Portable
09-11-2013, 02:54 PM -
by GstuverI have been using this technique on occasion to determine if a machined parts feature is located where it should be relative to datums. I'm wondering...
10-18-2017, 08:10 AM -
by cclayout2I have a CAD model which has a datum structure wich is out in space, and doesn't clearly relate to the surfaces of the part. Additionly, I have a print...
07-28-2008, 01:20 PM -
by bdotjdotkOk guys I would appricaiate some help here, I am used to programming with LKCamio, but now work with PCDMIS 3.7MR3. Here is the skinny. I start a new...
06-08-2008, 12:34 PM -
by Slug DawsonHello all. I have target points on my CAD model that I will need to probe during programming. The drawing has XYZ IJK clearly defined for each of the...
12-10-2009, 04:38 PM -
