https://www.wilcoxassoc.com/public/P...9_R1/SP11/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...9_R1/SP11/x64/
Release Notes - 2019 R1-SP11
• PCD-146826 - Fixed an issue where the Gaussian filter didn't work when you
created a measurement in the inch mode.
• PCD-163923 - Fixed an issue where PC-DMIS didn't show the correct leader
line style when you applied it from the Label Layout Wizard dialog box.
• PCD-164339 - Fixed an issue where both perpendicularity and parallelism
showed an incorrect color representation of the size deviation graphic colors.
• PCD-172988 - Fixed an application error that occurred when there were many
Write commands in a measurement routine.
• PCD-185747 - Fixed an issue where PC-DMIS took more time to export a
pointcloud file than usual when you exported a psl file.
• PCD-186451 - Fixed an issue where PC-DMIS prevented the clearing of a
feature list when you selected a new geometric tolerance from the Xact
Measure dialog box.
• PCD-189807 - Fixed an issue where PC-DMIS was not able to export ESF
(VWMP) features to a DMIS file.
• PCD-191049 - Fixed an issue where the variables with a fixed text were
imported incorrectly when you imported a DMIS file.
• PCD-191254 - Fixed a software crash that occurred when you opened the
Constructed Plane dialog box and selected Primary Datum from the list.
• PCD-192158 - Fixed an issue where Q-DAS Configurator doesn't output the
correct value for the legacy Profile Form and Location.
• PCD-192526 - Fixed an issue where the Shift + right mouse button in the
Graphic Display window corrupted the mouse controls.
• PCD-195513 - Fixed an application error that occurred when you pasted an
ESF feature that doesn't carry a standard VW name.
• PCD-195962 - Fixed a software crash that occurred when you performed a
laser scan in Dual Arm mode.
• PCD-198324 - Fixed an issue where PC-DMIS showed an error message
when you created a QdasData.xml file with a legacy true position dimension
with axes in polar coordinate.
• PCD-199068 - Fixed a software crash that occurred when you created a plane
through the feature widget and attached a plane circle scan strategy to it.
• PCD-199946 - Updated a DLL to fix a software crash that occurred when you
closed a measurement routine.
• PCD-203241 - Fixed an issue where the COP command was incorrectly
removed from the Edit window when you opened and closed the Caliper
Gage dialog box without any changes.
• PCD-204936 - Fixed a software crash that occurred when you opened a
measurement routine with CAD GD&T elements.
Measure dialog box.
