Solved-->
Print was changed from circular runout to total-runout.
Never got a straight answer as to why PCD wouldn't do circ runout of a pln in legacy...I definitely understand what people (specifically kirby) was saying about a pln being 3d and circular runout being 2d... but you CAN measure circ runout on a plate with an indicator so i was surprised that the software wouldn't let me duplicate this w/o having to do a workaround. Oh well, thanks for all who offered input
__________________________________________________ __________________________________________________ _____________________________________
Original Post-->
PC DMIS 2020 R2 SP4
I use legacy dimensions.
I have measured a plane. My print requires I report the runout of that plane back to some datums.
I click "runout", then realize PC DMIS doesn't show me any planes in the box, it only allows me to pick from circles, cylinders, and lines in my prg. I have to switch out of legacy and into xact (or whatever tis called now) and only from in there can I select the plane I want.
Why won't it let me dimension the runout of a plane using legacy dimensions? IK its called circular runout but it is very well established in the industry to measure the circular runout of a planar surface on a surface plate (with the corrct fixturing & using your indicator correctly), why wouldn't PCD allow for this?
Original Post-->
PC DMIS 2020 R2 SP4
