I have an old program that was proven out and worked fine up until I installed the 2020 R2 software now the True position is way off even if I run known good parts. anyone else have this issue? did they change something in the software?
PCDMIS 2020 R2 True Position
There have been BIG changes to the software. The latest revision of Y14.5M has redefined/changed the default calculation math for some important stuff & the software has evolved along with it to suit these industry requirements.
Hexagon has posted some really good videos with their senior level people explaining the changes, really helped me out a lot. Highly suggest you start looking into this stuff.
The above being said...you're gonna have to post that code or we can't help you my friend. There are way too many potential things that could be messing you up.Last edited by DAN_M; 01-13-2021, 10:50 AM.Beep beep beep..
- 1 like
This is where to find the link to the webinar recording https://www.pcdmisforum.com/forum/pc...419#post481419
There is also a wealth of information in the help files here : https://docs.hexagonmi.com/pcdmis/20...rol_Frames.htm
Dan,
You say big changes to the saftware, but OP is talking solely about TP...its calculated on the most basic math and its never going to change...its simple trig really....he needs to post code so we can see where the problem lies...I wish people would learn that they cannot come here and say, " What is wrong or going on"....thats like saying, "why doesn't my car start"...could be dozens of things, but without being able to eliminate some variables, we are just throwing darts in the dark...( Which I have done when I was younger and ended up with one sticking out of my forehead after !! LOL )Jim Jewell
jjewell
Hi Jim, big changes have occurred to the software my friend!
For years, the industry has been struggling to come up a "UNIVERSAL" best fit math type when having a software "calculate" what a feature looks like. This is in effort to improve data correlation from supplier to supplier/across the board.
The release of Y14.5M-2019 settles this discussion and instructs the industry to STOP using LESTSQU as the DEFAULT best fit math type and use something called "Constrained L2" as the DEFAULT. When you use "XACT" and create a feature control frame, PC DMIS will now default to this "Constrained L2" math.
Constrained L2 (very similar to ISO's Chebyshev) eloquently eliminates rock in the software's calculations and best duplicates what you'd get if you had the datum resting on a surface plate. Even with really waffly/deformed "chip" looking parts (that are supposed to be flat) this calculation minimizes distortion in a highly repeatable way and will yield results that correlate to a much higher degree with other methods.
I have done some testing myself. Measured a simple T.P. using 2019 then 2020R2. Even though you're totally correct and the formula for T.P. remains the same, the PLANE for the alignment gets calculated differently AND the circles that are being measured look slightly different to the software so the results came out slightly different (we're talking 0.0005 difference on T.P. and 0.0005 difference on dia size...but for me thats a good amount of my tolerance).
Hexagon has published some webinars about this stuff, suggest you give it a look! Hope this info was helpful.Last edited by DAN_M; 01-13-2021, 04:36 PM.Beep beep beep..
- 2 likes
if the CMM says its good, its a true position. if it rejects it, its a FALSE position =(Last edited by DAN_M; 01-13-2021, 04:58 PM.Beep beep beep..
- 1 like
by DarrollhGood morning,
This is probably in the wrong place but I am trying to get dimensions from a drawing with TP. How do I go about that without involving...-
04-17-2019, 10:25 AM -
by jamesjr57Could someone please help me with the best way to define true position versus concentricity? I know the difference but when explaining it to my toolmakers,...
07-22-2009, 05:28 PM -
by Ken8282I recently did a true position and may 321 alignment to the datums and picked the feature to be true positioned but I get a smaller TP than if I do a...
04-30-2018, 03:38 PM -
by GuestCan anyone tell me what the formula is for True Position? For whatever reason this engineer thinks that the true position should have a bilateral tolerance....
06-12-2008, 07:22 PM -
