I'm having problems with intersecting two lines. I know it should be simple as can be but I'm getting bogus numbers. I'm attaching a simple sketch and my code.
DeWain
Maybe its me, or the fact that its really late on a Sunday, butt those two lines seem to be parallel. But at worse case if they do intersect, are you in the correct view to intersect?
Try creating your lines from auto vector snap points. I've had better luck creating lines from points than using the auto line. what version are you running? The guru's will be in at 6:00 or 7:00 they have bankers hours
sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
Well maybe I just need more coffee, but you sketch does not make a lot of sense to me. I did notice that the THEO vector for both of your lines is 0,-1,0 but the actual vector for each line is 0,0,-1 ! ! !
Despite being a wiseacre, Mr. Henger is probably correct that constructing your lines from vector point might be the better way to go.
Also sometimes when intersection does not work, pierce will. HTH
Attached is a pic of something I'm trying to do on PCDMIS version 3.7. I've tried constucting a plane at the intersection of the sphere and angle (because...
I attached a screen shot for reference. Not easy to explain so hopefully that helps. I need to create intersection points between LIN1/LIN2 and a virtual...
Sooo, I have started to use this quite often. But I have to mess with it to get it to work correctly, I just make changes until.... it works.... MAGIC...
