Temperature compensation - Issue switching form 2017 to 2020
  • Temperature compensation - Issue switching form 2017 to 2020
    Hello,
    We recently upgraded to version 2020 R1 from 2017 R2. In 2017 when we used this code:
    TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Calibration Sphere Ceramic,CTE=8
    ,SET WARNING LIMIT = TRUE,MINIMUM = 50,MAXIMUM = 86
    ,PART SENSOR NUM=DEFAULT,X SCALE= 69.314,Y SCALE= 69.71,Z SCALE= 70.076,PART TEMP=69.566
    The axial temperatures (in Fahrenheit) would be included in the report. Since we switched over, they are no longer output to the report. Does anyone know a way to get then temp comp to output to a report?
    Thank you
    Jim Bagley
    Quality Tech
    SMC
    check out and look at question #1 This might help you out.
    It will stick if you throw it hard enough.
      Thanks for the help! I'll check it out further.
