We recently changed versions from 2017 MR2 to 2019 MR 1 and I've been able to tweak just about everything to the way we like it with the exception of a few things.
- When we make a new program, we get a question to turn temp comp on. Is there a way to prevent this from happening? We never use it.
- We use vector points for the majority of our measurements, but the auto feature tool is coming up with Avoidance Move defaulted to Both. Is there a way to change the default to none? We normally use clearance planes and manually enter where we want them. I created a new program, didn't add any features, opened the Vector Point window and changed Avoidance move to None - then closed the file and created a new program, and it had reverted back to Both.
- We use Execution Report Print Setup to save a PDF of the measurement results to a specific network location. This works as it should on the main programming machine, but when we send the program to the shop, the reports go to a completely different local folder. This folder doesn't match any of the Set Search Path locations and I can't find any reason why it's choosing this location.
