Skewed Plane and Skewed Hit Results
  • Skewed Plane and Skewed Hit Results
    Having some issues with a program, I've got a work around, but some of the things I'm seeing has raised some questions. So I'm running an experiment. So far I've ran the same fixtured part without moving it 9 times. Any insight on why the demon is doing what it's doing in these 3 numbered issues? Thanks.
    1) Part is nearly perpendicular to MCS. At this point in manual alignment, I've leveled to X+, Rotated to Z+, and translated to X & Z. The final 2 points establish the Y axis translation.
    If I lock my Z axis travel, 6 out of 6 times I get good results between the 2 points and the program runs.
    But if I don't lock the Z axis travel, 3 out of the 4 times the hit results make no sense at all. The Y & Z values should be within .5" of each other at absolute worst case scenario.
    1st run, Point B4 has Y @ 8.799, Z @ -1.9582. Point B5 has [email protected] .8592, Z @ -7.5833
    2nd run ok, Y values within .15" of each other
    3rd run, Point B4 has Y @ -3.1692, Z @ -7.1652. Point B5 has [email protected] 5.3791, Z @ -2.4503
    4th run, Point B4 has Y @ 7.6684, Z @ -1.3922. Point B5 has [email protected] .4793, Z @ -8.263
    I reviewed the data ahead of this, and every time the vector of level plane is .999... in X and rotate line vector is .999... in Z, so nearly perpendicular to machine. So why would my results be so skewed in Y and Z when they should be reasonably close to each other?
    2) 2 out of 6 times it has skipped the incremental move to clear the part right after going in to DCC mode. Any ideas why?
    3) One time it created the plane below. All 3 of my points are nearly perfect X plus vector, with not much deviation in the X results. Yet the plane constructed from them is this skewed 3D monstrosity that would have crashed the head if I wasn't watching it once going into DCC. Not sure on how the math behind the plane creation works, but in my mind, if all 3 points have the same vector, than that's the vector that the plane is created on. Any insight?
    Thanks
    Can you post your code with actual measured values included?
      For #1, as mentioned above, we would need to see your code for the alignment and features in question.
      For #2, This happens to me sometimes when I have a MOVE/CLEARPLANE command right after a CLEARP/ command. PC-DMIS can get ahead of itself sometimes, try putting a MOVE/INCREMENT,<0,0,0> right before the move that it sometimes skips. This way, if PC-DMIS gets ahead of itself, it should skip the zero move and execute the actual move.
      For #3, your picture is not showing up, so I cannot see what you're talking about. But the vector and position of a plane is calculated ONLY from the measured XYZ values of the points that make it up. It has nothing to do with the vectors of those points.
        1. Code added below. It doesn't include the measurement values listed above, but values from a good run. We don't save anything other than the most recent run.
        3. Reattached picture, hopefully it works this time.
        Thanks for taking the time giving me input.
        PNT_X1_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0,0.327,0.8112>,<1,0,0>
        ACTL/<14.1465,8.745,-26.0887>,<0.9999955,0.0029955,0>
        TARG/<0,0.327,0.8112>,<1,0,0>
        SHOW FEATURE PARAMETERS=NO
        SHOW CONTACT PARAMETERS=YES
        SHOW HITS=NO
        PNT_X2_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0,0.9037,0.6963>,<1,0,0>
        ACTL/<14.1316,9.4387,-25.9086>,<0.999991,0.0042462,0>
        TARG/<0,0.9037,0.6963>,<1,0,0>
        SHOW HITS=NO
        PNT_X3_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0,2.5106,1.8651>,<1,0,0>
        ACTL/<14.1274,10.6118,-25.088>,<1,0,0>
        TARG/<0,2.5106,1.8651>,<1,0,0>
        SHOW HITS=NO
        PLN_X_MAN =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
        THEO/<0,1.2471,1.1242>,<1,0,0>
        ACTL/<14.1352,9.5985,-25.6951>,<0.9986558,0.0320459,-0.0407382>
        CONSTR/PLANE,BF,PNT_X1_MAN,PNT_X2_MAN,PNT_X3_MAN,,
        OUTLIER_REMOVAL/OFF,3
        FILTER/OFF,WAVELENGTH=0
        MAN_LEVEL =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
        ALIGNMENT/LEVEL,XPLUS,PLN_X_MAN
        ALIGNMENT/TRANS,XAXIS,PLN_X_MAN
        ALIGNMENT/END
        TIP/T1A90B180, SHANKIJK=0, -1, 0, ANGLE=180
        COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
        LOCK (X) AXIS TRAVEL ON CONTROLLER FOR NEXT (2) HITS
        PNT_Z1_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<-2.33,-0.09,-0.589>,<0,0,-1>
        ACTL/<-2.3723,7.3564,-27.0372>,<0.0407382,-0.0013062,-0.999169>
        TARG/<-2.33,-0.09,-0.589>,<0,0,-1>
        SHOW HITS=NO
        PNT_Z2_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<-2.33,-0.09,1.811>,<0,0,1>
        ACTL/<-2.4675,7.3899,-24.6711>,<-0.0408175,-0.0011703,0.9991659>
        TARG/<-2.33,-0.09,1.811>,<0,0,1>
        SHOW HITS=NO
        LIN_Z_MAN =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
        THEO/<-2.33,-0.09,-0.589>,<0,0,1>
        ACTL/<-2.4199,7.3564,-27.0372>,<0,0.0141389,0.9999>
        CONSTR/LINE,BF,2D,PNT_Z1_MAN,PNT_Z2_MAN,,
        MAN_ROT =ALIGNMENT/START,RECALL:MAN_LEVEL,LIST=YES
        ALIGNMENT/ROTATE,ZPLUS,TO,LIN_Z_MAN,ABOUT,XPLUS
        ALIGNMENT/TRANS,ZAXIS,PNT_Z2_MAN
        ALIGNMENT/TRANS_OFFSET,ZAXIS,0.519
        ALIGNMENT/END
        WORKPLANE/ZMINUS
        TIP/T1A7.5B0, SHANKIJK=0, 0.1305, 0.9914, ANGLE=0
        LOCK (Z) AXIS TRAVEL ON CONTROLLER FOR NEXT (2) HITS
        PNT_B4_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0.42,0,-1.719>,<0,1,0>
        ACTL/<0.3641,7.7629,-1.4061>,<0,1,0>
        TARG/<0.42,0,-1.719>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        PNT_B5_MAN =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<-5.08,0,-1.719>,<0,1,0>
        ACTL/<-4.9622,7.9156,-1.6212>,<0,1,0>
        TARG/<-5.08,0,-1.719>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        LIN_B_MAN =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
        THEO/<-5.08,0,-1.719>,<1,0,0>
        ACTL/<-4.9622,7.9156,-1.5136>,<0.9995891,-0.0286632,0>
        CONSTR/LINE,BF,2D,PNT_B5_MAN,PNT_B4_MAN,,
        MAN_ALIGN =ALIGNMENT/START,RECALL:MAN_ROT,LIST=YES
        ALIGNMENT/TRANS,YAXIS,LIN_B_MAN
        ALIGNMENT/END
          One thing jumps out the vectors of the 2 hits used for the line are the same as the line vector that is wrong, for a Z vector line the hits should be in the X or Y.
          • Woody S
            Woody S commented
            Can you elaborate a bit more please? You're comment has piqued my interest. Obviously a line is simply two points connected, but I learn more every day how finicky PC-DMIS can be. So making a line thru the vectors, opposing vectors at that does seem like something that may cause problems in the PC-DMIS world. Just wondering what the impact could be. Thanks
          This is not about PC-DMIS being finicky but good metrology practice and understanding, see attached PDF as they say a picture says a thousand words.
          By locking the X Axis as you have the line created in the X workplane may not be representative of how the part could be orientated as the hits are free to
          be places along the Y axis. Locking the Y axis would not help either as this line would be the machine coordinate system Z axis and may not represent the part orientation.
          • Woody S
            Woody S commented
            Thanks UKCMM. For this part it wouldn't make a difference, flange is only .18" thick, so line can't skew very much. But trying to understand the bigger picture here.
            So since this is a 2D line with an X Workplane, the X values get averaged out and the line can be anywhere in the YZ plane, going from one YZ to the next. So hitting several inches apart in Y would create quite an angled line. But if I'm hitting X vectors I could still travel inches in Y and create that skewed line. So it seems like the way would be to hit only Y Vectors as far apart in Z as the part configuration allows, to control that actual part orientation and not create that skewed line. Is that correct, or am I still missing something?
            Or if I wanted to use X vector hits, change the workplane to Y?
            Thanks
          • UKCMM
            UKCMM commented
            To rotate about the X axis the 2D line needs to be created in the X workplane using either a Z vector line ( min 2 off Y+ or Y- hits ) or a Y vector line ( min 2 off Z+ or Z- hits ).
            If you want to use a Z vector 2D line using X vector hits in the Y workplane you cannot use that the rotate about the X axis.
            Can you attach a sketch of the part to better understand the features you are measuring.
          • Woody S
            Woody S commented
            Thanks for your feedback UKCMM, when I get a little opening in time I'll mock something up.
