I'm scanning with SP25M sensor several AutoLines and AutoCircles on two cylindrical surfaces (one is an outer surface and the other is an inner surface).
After several parts without fail, it happens that after finishing a certain scan, not always the same one (sometimes is a circular scan, and other times a line scan) the mentioned error arises:
"TR_MOV01 Movement interrupted" and then the command in the execution window is: "Absolute Move to X=...." that corresponds to a ClearPlane move.
I've realised that it usually happens when the movement of the probe after finishing the scan is aligned approximately with the X axis direction.
Is there any known cause for this error?
Thanks in advance.
Thanks in advance.
