2019 r2 sp9
  • 2019 r2 sp9
    https://www.wilcoxassoc.com/public/P...19_R2/SP9/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP9/x64/
    Release Notes - 2019 R2-SP9
    • PCD-185747 - Fixed an issue where PC-DMIS took more time to export a
    pointcloud file than usual when you exported a psl file.
    • PCD-187629 - Fixed an issue where the paste operation didn't work properly
    when you copied the measurement sequence from one measurement routine
    into another.
    • PCD-193861 - Fixed an issue where PC-DMIS showed an incorrect message
    when you added Point of Interest (POI) in the Thickness Gage dialog box.
    • PCD-194376 - Fixed an issue where PC-DMIS didn't create a point pair
    alignment when you clicked on points on the CAD model.
    • PCD-194852 - Fixed an issue where PC-DMIS showed a black background in
    the DOF area of the Best Fit Alignment dialog box.
    • PCD-194875 - Fixed an issue where PC-DMIS didn't create annotation points
    to a selected CAD face for a Point Colormap when you marked the Create
    annotation points check box in the Pointcloud Operator dialog box.
    • PCD-195227 - Fixed an issue where PC-DMIS would color the Pointcloud
    Thickness Colormap red when you clicked the Apply button on the
    Pointcloud Operator dialog box instead of the Thickness colors when
    working in Inch units
    • PCD-195832 - Added the new names for TesastarMP US components and
    support for the 6-way module.
    • PCD-198971 - Fixed an issue where the CWS Thickness Scan didn't work
    with the feature-based measurement.
    • PCD-200143 - Fixed a software crash that occurred when you changed the hit
    target direction in the Live View for the 2D profile.
    • PCD-200965 - Fixed an issue where, instead of executing the COP/OPER,
    EXPORT command from a subroutine, PC-DMIS would display an error
    message.
    • PCD-201077 - Fixed an issue where auto calibrate didn't work when a
    machine was in Manual mode which caused PC-DMIS to report collisions that
    did not exist.
    • PCD-201313 - Added definitions for the HP-Te series of probes.
    • PCD-201556 - Fixed an issue where new measurement routines couldn't send
    their file name to the HxGN SFx | Asset Management.
    • PCD-201881 - Updated device drivers for the Heidenhain IK5000 (Metronics)
    controller.
    • PCD-201970 - Fixed a software crash that occurred when you imported the
    NX part file from the File | Direct CAD Interfaces | NX menu item.
    • PCD-202002 - Fixed an issue where the vision features had an incorrect
    calibration when you used the illumination override on a feature.
    • PCD-202099 - Fixed an issue where the CAD model views indicated the
    incorrect presence of the GD&T features when PC-DMIS added the icons
    next to the views without PMI.
    • PCD-202759 - Fixed a software crash that occurred when you clicked OK in
    the Thickness Gage dialog box after you edited the Point of Interest value
    for the command.
    • PCD-203000 - Fixed an issue where PC-DMIS failed to set the tolerance to a
    negative value in the Thickness Gage command when you changed from the
    Edit window.
    • PCD-203163 - Fixed a software crash that occurred when you executed
    thickness scans.
    • PCD-203241 - Fixed an issue where the COP command was incorrectly
    removed from the Edit window when you opened and closed the Caliper
    Gage dialog box without any changes.
    • PCD-203293 - Fixed an issue where the Report Output check box was
    automatically deselected in the Output Configuration dialog box when you
    clicked the Print Full Report button in the Marked Sets window.
    • PCD-203601 - Added bonus tolerance to the K0060 field for the .dfq output
    file in Q-DAS Configuration.
    • PCD-203865 - Fixed an issue where PC-DMIS changed the internal
    dimensions when you pressed F9 to open the Thickness Gage dialog box
    and closed the dialog box without any changes.
    • PCD-204106 - Fixed a software crash that occurred when you created a
    construct feature set from the COPCLEAN command.
    • PCD-204302 - Fixed an issue where PC-DMIS didn't show an error message
    when decimal symbol comma didn't convert to decimal point in the Windows
    regional settings for the number formats.
    • PCD-204360 - Fixed an issue where an event was missing in the
    EventModule.xml file in the onStartingApplication command.
    • PCD-204457 - Fixed an issue where the tabs in the Best Fit Alignment
    dialog box were not displaying properly on high resolution monitors.
    • PCD-204558 - Fixed an issue where the CWS scan reported no points even
    though the scan was successful.
    • PCD-204562 - Fixed an issue when PC-DMIS didn't retain the tolerance
    values of the internal min/max dimensions when you edited the values in the
    Edit window.
    • PCD-204661 - Fixed an issue where the size command was not able to
    calculate the ISO limits and tolerance when the tolerance was associated with
    an ISO 286 tolerance code.
    • PCD-204858 - Fixed a software crash that occurred when you edited the
    thickness gage dimensions from the Thickness Gage dialog box and used
    internal command suffixes in the feature names.
    • PCD-204861 - Fixed an issue where lines didn't join polylines properly when
    you created a thickness scan on the CAD.
    • PCD-204936 - Fixed a software crash that occurred when you opened a
    measurement routine with CAD GD&T elements.
    • PCD-206263 - Fixed an issue where PC-DMIS showed an incorrect nominal
    value of the internal distance dimension for a Point of Interest (POI) with zero
    gage distance.
    • PCD-206597 - Fixed an issue where the positions of the Graphic Window in
    Y+ and the Graphic Window in Y- icons were reversed in the Graphic View
    toolbar on the high resolution monitors.
