I Tryed something and it will suffice ~ Under View set-up I turned on the graphical 3d grid and set the grid spacing to 1" in X,Y, & Z. It is good. Thanks for the UV scan tip. That would work also but for this situation I can skin the cat a little differently.
I am checking the trim on a stamped part where the form is layed out and the trim is on an angle to the form surface. When I use and edge point it projects...
Looking for insight, only occasionally when I create an edge point it will show different results as a surface point at the same location. The surface...
