2020R2Sp4
  • 2020R2Sp4
    http://software.hexagonmi.com/public...20_R2/SP4/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R2/SP4/x64/
    Release Notes - 2020 R2 SP4
    • PCD-161334 - Fixed an issue where PC-DMIS couldn't box-select a laser scanned circle when you performed a pointcloud alignment to features.
    • PCD-187399 - Fixed an issue where PC-DMIS didn't populate the updated cone height value in the Construct Circle dialog box.
    • PCD-193861 - Fixed an issue where PC-DMIS showed an incorrect message when you added Point of Interest (POI) in the Thickness Gage dialog box.
    • PCD-194919 - Fixed an issue where PC-DMIS took a long time to compute Pointcloud Surface Colormaps when you imported an STP file.
    • PCD-195720 - Fixed an issue where PC-DMIS showed incorrect color for the Mesh Thickness colormap when you compared with the CAD annotation.
    • PCD-198318 - Fixed an issue where PC-DMIS removed the Mesh data in the Graphic Display window when you edited the MESH/OPER,SELECT command in the Mesh Operator dialog box.
    • PCD-198971 - Fixed an issue where the CWS Thickness Scan didn't work with the feature-based measurement.
    • PCD-199080 - Fixed an issue where each feature's point was drawn as a hit in the Graphic Display window when you selected a Laser Auto feature in the Alignment Utilities dialog box.
    • PCD-201881 - Updated device drivers for the Heidenhain IK5000 (Metronics) controller.
    • PCD-201911 - Fixed an issue where the variable tolerance calculations were not migrated properly for the Xact measure command to the geometric tolerance command.
    • PCD-202401 - Fixed an issue where PC-DMIS didn't automatically clear the position diameter check box in the Excel Form Report when you cleared the check box in the Geometric Tolerance dialog box.
    • PCD-203000 - Fixed an issue where PC-DMIS failed to set the tolerance to a negative value in the Thickness Gage command when you changed from the Edit window.
    • PCD-203163 - Fixed a software crash that occurred when you executed thickness scans.
    • PCD-203241 - Fixed an issue where the COP command was incorrectly removed from the Edit window when you opened and closed the Caliper Gage dialog box without any changes.
    • PCD-203663 - Fixed an issue where PC-DMIS removed the Mesh data in the Graphic Display window when you pressed Ctrl + U to execute the MESH/OPER,SELECT command.
    • PCD-203865 - Fixed an issue where PC-DMIS changed the internal dimensions when you pressed F9 to open the Thickness Gage dialog box and closed the dialog box without any changes.
    • PCD-204558 - Fixed an issue where the CWS scan reported no points even though the scan was successful.
    • PCD-204562 - Fixed an issue when PC-DMIS didn't retain the tolerance values of the internal min/max dimensions when you edited the values in the Edit window.
    • PCD-204569 - Fixed an issue where the labels for the Surface profile Dimensions of the geometric tolerance command were corrupted when you dragged the dimension from the Edit window into the custom report.
    • PCD-204861 - Fixed an issue where lines didn't join polylines properly when you created a thickness scan on the CAD.
    • PCD-204963 - Fixed an issue where spherical surfaces didn't tessellate correctly when you imported some CAD models.
    • PCD-205590 - Fixed an issue where PC-DMIS allowed you to edit the measured value in the Edit window for the ESF (VWMP) features.
    • PCD-205780 - Fixed an issue where the BD (ESF, VWMP) features were not available when you opened existing measurement routines. This issue also fixed a software crash that occurred when you clicked Create in the Extended Sheet Metal Features dialog box.
    • PCD-205801 - Fixed a software crash that occurred when you clicked Cancel in the Ring Light Migration dialog box after you clicked Yes for migration in the warning message.
    • PCD-206045 - Fixed an issue where PC-DMIS didn't show a minus sign in the .dfq file for the geometric tolerance command.
    • PCD-206086 - Fixed an issue where PC-DMIS couldn't take the hit on the CAD under a feature glow when you selected Adaptive Circle Scan in the Auto Feature dialog box.
    • PCD-206166 - Fixed an issue where PC-DMIS didn't configure the laser hardware properly in the Machine Options dialog box when you used the HSI_CMM interface.
    • PCD-206263 - Fixed an issue where PC-DMIS showed an incorrect nominal value of the internal distance dimension for a Point of Interest (POI) with zero gage distance.
    • PCD-206392 - Fixed a software crash that occurred when PC-DMIS tried to overwrite the existing viewset after you clicked Yes in the warning message.
    • PCD-206488 - Fixed an issue where PC-DMIS used full precision instead of the measurement routine setting in the .dfq file.
    • PCD-206597 - Fixed an issue where the positions of the Graphic Window in Y+ and the Graphic Window in Y- icons were reversed in the Graphic View toolbar on the high resolution monitors.
    • PCD-207353 - Fixed an issue where PC-DMIS showed the same graphic for the lower segment and upper segment for the geometric tolerance position FCF in the report.
    • PCD-207512 - Fixed an issue where a lower segment couldn't use a feature or datum math type that was different than the setting in the geometric tolerance command.
    What happened to avoidance moves in auto features and void detection no longer has a place to change how much to avoid the edges by in void detection for any Auto feature
    Michael A Wildschutz Sr
    I Walk on The WildSide
    "To Each is Own"
      JEFMAN You're always first out of the gate with new service pack notices! Thanks for posting this - much appreciated.
      CMMXYZ Applications Specialist: PC-DMIS Support and Training. Check out my PC-DMIS tutorial videos... https://blog.cmmxyz.com/blog/tag/cmm-tech-tips
