I have this part with 2 holes and each hole has a secondary true position reference frame. Both frames are related to datums ABC but what does it mean when a hole has two TP callouts? And how should I get each of those measurements on PC-Dmis?
Help with two true position callouts on a single hole
by Mike RuffI was reading thru the ASME Y14.5-2009 handbook and came across something I haven't really paid much attention to before. In Section 7.4.2, it says...
03-09-2020, 01:07 PM -
by sscandlonI am having trouble correctly imputing the tolerance for the true position of the pin holes on my part as well as relating them to one another so that...
03-11-2019, 11:39 AM -
by pnwenz89All,
I am trying to measure a 4mm hole on a diameter. This hole has a positional tolerance of .2mm from a diameter. I do not have a CAD...-
06-01-2020, 02:10 PM -
by Reedy93Hi everyone,
I have a query regarding TP dimensions and the correct way to output them. Please see attached image of a distance between two...-
08-24-2018, 07:49 AM -
by Jignesh1. One True position of Hole in drawing with Dia. symbol and 0.3 MM. tolerance. It means I need to imagine 0.3 MM. Diameter circle surrounding Theoretical...
02-28-2019, 01:38 PM -
