which format do you guys have the least amount of trouble with I usually can get my Models in IGES or STEP Formats. I was wondering which is best
from a PCDMIS point of veiw
sigpicTHE TASK AHEAD OF YOU, IS NEVER AS GREAT AS THE POWER BEHIND YOU. I Fight for Freedom and Pray For Peace..
If it is coming from UG, your best bet is STEP. Too many times I get garbage and more garbage and missing stuff in IGES files from UG (probably the yahoo running the software) but the step files usually come in fine, even if it takes them 3 or 4 times as long to import as the iges files do.
Transmagic software works well to repair CAD models. We usually export out models as .sat files and then translate them to both IGES and STEP with it. It allows you to perform repairs on the CAD model, i.e. restitch surfaces and such. It will handle most all model types. We run Autodesk, but I get all types of CAD from customers. As far as the original question, I mostly us STEP.
Transmagic software works well to repair CAD models. We usually export out models as .sat files and then translate them to both IGES and STEP with it. It also allows you to perform repairs on the CAD model, i.e. restitch surfaces and such. It will handle most all model types. We run Autodesk, but I get all types of CAD from customers. As far as the original question, I mostly us STEP.
How much and where do I get the Transmagic software Your Talking about
Right Now I have nothing but Pcdmis to veiw Models and I have to Rely on
The I.T. Dept Or engineering to convert & or repaire (And don't even get me started there) My Boss would like Me to handle all these things and ask me to get a quote On software. I'm just not sure where to start.
OH Yeah thanks for all the help you guys have given me directly and indirectly
Thanks again
Greg
Though very good software, but we dont use it. The powers at be dont want to spend money to get good CAD data. Yet of course they want perfect near instant results all the time.
The transmagic I-STEP will run you about $895.00 and the Transmagic Standard about $3,995.00
It depends mainly on what type of files you want to translate from directly.
From Autodesk stuff I prefer to use IGES, and then use the IGES Alternate PCDMIS import utility.
3.2063 here - .igs files seem to work better for me. If I receive either .stp or .igs out of Pro-E or UG, I bring them into Solidworks and export them back out as an .igs. Very rarely do I have any bad surfaces that way.
I have found it to be very dependant on the model.
Most of the time I start out with step,
I try iges next if I have problems.
I even resort to .stl files,
sometimes they come in better than step and iges.
I've already had to make and use all three for various features on the same part.
Also remember the igs set. If you have a problem with the igs surfaces not trimming try going to the igs set and pick B curves. Back when I ran cad systems it was common use B curves for trimming. I just used it today. I one surface not trimming and when I changed the setup it was fine.
It dosn't allways work but worth the try.
I'm using v3.5mr2 not sure about newer versions.
1) go import
2) pick file and to merge or not then OK
3) go to setup
4) OK
5)process or whatever it says
