I am reporting the depth of some angled flat bottomed holes as a true position. I have drafted a basic drawing to explain the feature and the DRF. I have tried reporting it with the X, Y and Z ticked in the 'Nominals' tab, and with just the X ticked. I have also reported the depth as a T value. None of the results tie up with one another. Datum plane A is a plane on the face, datum B is the Ø10mm hole as a cylinder and datum C is a midpoint in the 10mm slot. Can anyone advise: 1. Am I using the correct features to define my datums (not A, just B and C) and 2. What is the correct process for generating the results with regards to the axis selection tick boxes in the nominals tab. Thanks in advance.
True Position of Angled Hole depth
Offset your alignment 40.2 from Dat A, then rotate 25° around, then you should just report in one axis and the nominal should be 60.Automettech - Automated Metrology Technology
- 1 like
Doesn't just have to be on co-axial features @DAN_M.
A-B on a plane-cylinder is perfectly valid, as is A-B on two holes (In effect you're splitting the difference between them so neither had precedence).
https://www.dropbox.com/s/0lq4yj7v8w...datum.JPG?dl=0
I can't remember where I got that from, I'm guessing it was an ISO standard but I can't be certain (looks like it though).
by rebeldudeI am trying to get the true position for a hole that is on a different depth of the sheet metal part. Datum A actually is set from 2 points on one depth...
07-18-2006, 07:34 AM -
by MJA75Ok guys, heres my 2nd question,
Measuring a part that is basically a cylinder (along x axis), we will call it datum A.
Hole perpendicular...-
02-09-2008, 11:52 AM -
by kcassadayI'm having a problem understanding how can you call out the position of a hole to the plane in which it resides. For instance, Datum A is the surface...
02-28-2018, 09:39 AM -
by TAC45A couple of questions about true position call outs for datums.
1) I have a 4 Way "B" Datum hole. This hole resides on the primary...-
02-07-2019, 01:51 PM -
by operator1I'm in the process of recreating a program for this part, changing the setup in hopes to get better results--or at least the program going all the way...
10-11-2007, 10:29 AM -
