I do a stability study each week with a program I have built. I use a 6" x 6" angle which I place in different location on the table and then run the program 5 times in that location. I would like to come up with a way to have my program chose the location randomly for me. Does anyone have a idea how I might be able to do this. I am using a RACO PLATE, with holes located from A1 to SS37 so I do have a defined group of numbers "locations".
Random numbers?
Open excel
label cells with the appropriate numbers
put borders around the cells
print out spreadsheet
cut along boarder lines
place small pieces of paper in a plastic container with lid
place lid on container
shake thoroughly
close eyes pick out a number
repeat tomorrow
shake thoroughly
repeat tomorrow
Originally posted by Matthew D. Hoedeman View PostNO! Simply find a good 'gamers' store, D&D, Magic, that kind of thing, and get yourself a set of percentile dice (2 10-sided dice) and use them to randomly generate a number from 1 to 100, 'grid' the machine to 100 spots, use what you roll for placement.
Simply turn your back on the machine, grab the thing you measure, toss it over your back onto the table, measure it where it stops.sigpic
=rand() * (1-37) + 37Last edited by craiger_ny; 05-18-2007, 09:40 AM.<internet bumper sticker goes here>
Originally posted by Tested View PostI do a stability study each week with a program I have built. I use a 6" x 6" angle which I place in different location on the table and then run the program 5 times in that location. I would like to come up with a way to have my program chose the location randomly for me. Does anyone have a idea how I might be able to do this. I am using a RACO PLATE, with holes located from A1 to SS37 so I do have a defined group of numbers "locations".
So, you need a random number from 1 to 1665 OR you need 2 random numbers, 1 to 37 and 1 to 45. You can do this easily in Excel and then use those results to place the detail you are checking.
Excel formula: =RANDBETWEEN(1,37)
Personally, I would use the 2 random number method, one for the row and one for the column. Hit F9 to get a new set of numbers.sigpic
Hi All, i have only been using our Dea Global CMM for one year using dmis 4.1 software , in that time have not really used it very much, what i would...
02-12-2007, 04:10 AM -
by ClayOgreOur CMM's were on a 6 month calibration schedule. However, with the current spate of cost cutting measures, they want to go to doing a calibration every...
02-12-2009, 02:11 PM -
Just wandering what kind of base plates are being used by everyone (or do you use one). We are in the process of making one out of steel since we can...
09-20-2006, 11:54 AM -
by RichVPAll,
Is it possible to create one program and put in coding at the end of it to automatically open and run the next program from another...-
01-18-2016, 04:02 PM -
by Tomi530iI'm Sorry for my question but I new CMM operator.
I have a program I wrote last week to check some parts. This week I have the same parts to check....-
06-12-2008, 09:00 AM -
