4.2 / Stats Count
  • 4.2 / Stats Count
    Anybody else get the stats count not correct in 4.2? I'm running a 30pc capability with the stats going to DataPage and the report printing at the end of each part. PC-DMIS says part #1 is part #1, Datapage says part 1 is part 1, but the report says it's part #2. They are all off by 1. #1 does not print as #1.
    Am I missing something, or is this widespread?
    Thanks in advance, and Happy Friday.
    It has done that for a long time, depending on HOW you printed to a file. If you look at the STATS COUNT line, it has been right in th epast, however, I have custom headers that I use and I always delete out the PC-DUMASS header stuff and just leave my custom header. Part of the custom header is the command:
    SAMPLE NUMBER = #SEQUENCE
    where #SEQUENCE should pull the current stat count value and report it. It has ALWAYS added one to the stat count value. If that is what you are using to get the stat count in the report, I would not be surprised that it is wrong. This was reported BY ME to BS at one time.
      I may not be much help here because I haven't loaded 4.2 yet (not planning on doing it until I return from vacation on the 29th) but I had that going on with 4.1... Is it automatically printing the report or are you manually printing the report?
      PCDMIS 2012
      Windows Office XP
        4.2 Stats
        I have the same problem here.
        designed a label for the footer in 4.1 to mimic the earlier version in 4.1 will not take in 4.2 yet. I keep on working on it.
        2014 SP5, DataPage + v5.0 #331
        [testing v2015.1]
          Its a bug. Same problem for me as well
          Mr. Comment
          SCIROCCO-NT 13-20-10
            Thanks for the responses.
              My guess is that is will be off by one since the stats count is written to the stats file & then incremented. This is done at program execute start so I imagine if the report grabs the info after that is performed it will grab the incremented number. I never really looked at that before.
                Did anyone figure out how to correct this issue? I decided to torture myself today by running 4.2mr1 and ran across this again...
                PCDMIS 2012
                Windows Office XP
                  Being the devils' advocate here...
                  Does it really matter? I run a study to capture the stats not a piece of paper. In fact, I don't print out paper copies of my studies, I only print to .pdf.
                    I think one solution is to edit the header template (or whatever template is being used) and change STAT_COUNT to STAT_COUNT-1
                      No, it really doesn't matter. It's just kind of annoying...
                      PCDMIS 2012
                      Windows Office XP
                      • zeljko
                        Stats count in report
                        by zeljko
                        Hello,
                        is there any option to change "stats count" in every report for the same part as i measure?
                        Simliar...
                        01-19-2016, 02:12 AM
                      • josip
                        Stats Count
                        by josip
                        Does anyone know How to change stats count to automatically?
                        I have to do it manually each time by start of a new measuring.Thanx
                        03-14-2008, 04:24 AM
                      • Sean Steele
                        Code to increment sequence number
                        by Sean Steele
                        Does anyone have some code that increments the sequence number on the report? We remove the main header from the reports that we give the customer becasue...
                        11-08-2006, 06:46 PM
                      • jmikefred
                        Stats Count
                        by jmikefred
                        We just upgraded yesterday to v4.2 from v4.0. I noticed tonight, when I'm running a program, the EDIT WINDOW and REPORT WINDOW will have the same STATS...
                        05-01-2008, 08:14 PM
                      • AuRules
                        Stats
                        by AuRules
                        I have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems...
                        04-02-2007, 09:37 AM
