2020 r1 sp9
  • 2020 r1 sp9
    http://software.hexagonmi.com/public...20_R1/SP9/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP9/x64/
    Release Notes - 2020 R1 SP9
    • PCD-82062 - Fixed an issue where the Copy Parameters functionality didn't work properly for the Laser Edge Point features.
    • PCD-129562 - Fixed an issue where there was an unexpected move on the adaptive circle scan when you used MOVE/CLEARPLANE.
    • PCD-188259 - Fixed a software crash that occurred when you used the HP-C-VE camera and the probe went to the focus position.
    • PCD-190082 - Fixed an issue with the automation interface that would cause the PC-DMIS application to not properly terminate.
    • PCD-194376 - Fixed an issue where PC-DMIS didn't create a point pair alignment when you clicked on points on the CAD model.
    • PCD-194852 - Fixed an issue where PC-DMIS showed a black background in the DOF area of the Best Fit Alignment dialog box.
    • PCD-195227 - Fixed an issue where PC-DMIS would color the Pointcloud Thickness Colormap red when you clicked the Apply button on the Pointcloud Operator dialog box instead of the Thickness colors when working in Inch units.
    • PCD-199080 - Fixed an issue where each feature's point was drawn as a hit in the Graphic Display window when you selected a Laser Auto feature in the Alignment Utilities dialog box.
    • PCD-201556 - Fixed an issue where new measurement routines couldn't send their file name to the HxGN SFx | Asset Management.
    • PCD-201881 - Updated device drivers for the Heidenhain IK5000 (Metronics) controller.
    • PCD-202609 and PCD-205590 - Fixed an issue where PC-DMIS allowed you to edit the measured value in the Edit window for the ESF (VWMP) features.
    • PCD-203000 - Fixed an issue where PC-DMIS failed to set the tolerance to a negative value in the Thickness Gage command when you changed from the Edit window.
    • PCD-203241 - Fixed an issue where the COP command was incorrectly removed from the Edit window when you opened and closed the Caliper Gage dialog box without any changes.
    • PCD-203601 - Added bonus tolerance to the K0060 field for the .dfq output file in Q-DAS Configuration.
    • PCD-203620 - Fixed an issue where the scanning parameters were incorrect for the Eagle Eye Laser scanning probe.
    • PCD-203628 - Fixed an issue where PC-DMIS would hang when you used the Quick Feature to extract an ellipse.
    • PCD-203865 - Fixed an issue where PC-DMIS changed the internal dimensions when you pressed F9 to open the Thickness Gage dialog box and closed the dialog box without any changes.
    • PCD-204106 - Fixed a software crash that occurred when you created a construct feature set from the COPCLEAN command.
    • PCD-204302 - Fixed an issue where PC-DMIS didn't show an error message when decimal symbol comma didn't convert to decimal point in the Windows regional settings for the number formats.
    • PCD-204457 - Fixed an issue where the tabs in the Best Fit Alignment dialog box were not displaying properly on high resolution monitors.
    • PCD-204558 - Fixed an issue where the CWS scan reported no points even though the scan was successful.
    • PCD-204661 - Fixed an issue where the size command was not able to calculate the ISO limits and tolerance when the tolerance was associated with an ISO 286 tolerance code.
    • PCD-204858 - Fixed a software crash that occurred when you edited the thickness gage dimensions from the Thickness Gage dialog box and used internal command suffixes in the feature names.
    • PCD-204861 - Fixed an issue where lines didn't join polylines properly when you created a thickness scan on the CAD.
    • PCD-204936 - Fixed a software crash that occurred when you opened a measurement routine with CAD GD&T elements.
    • PCD-204963 - Fixed an issue where spherical surfaces didn't tessellate correctly when you imported some CAD models.
    Thank you, dev team!
    PC-DMIS CAD++ 2o19 R1 SP11
