Auto-circle not registering outside hits
  • SingularitY
    If you mean that the points look like they are probing an internal hole instead of external, chances are the surface vector of the hole is flipped and it needs fixed. Otherwise, you can change the type of hole from internal to external in the auto circle dialog box.
    If you mean that the auto circle was done correctly before but the lines look weird and are flying off in space. Hit the Test button and itll fix the issue. It's just a visual glitch.
  • vraju2334
    started a topic Auto-circle not registering outside hits
    Hello guys,
    When i try taking hits on the outside surface of a cad using autocircle,its showing hits coming through the part on my graphic display window. Can anyone please tell me why this happens?
