Analysisview too small in PDF
  • Analysisview too small in PDF
    Hello together
    I have the problem that the analysisview is too small when i print a PDF file.
    In the report window the size is correct and also when I print the report the size is correct.
    It is only when I create a PDF it gets really small.
    Does someone know what could be the reason for this behavior?
    I guess I have to change something in the Settings-Editor.
    In the report window & when I print:
    In the PDF:
    Bump
    I tried already to look in the help file but couldn't find anything.
    I also tried look at the settings editor and see if I can find anything obvious.
    But it has too many entries to just go through all of them.
        Sounds pretty glitchy. Might want to reinstall your PDF driver. You can find a folder in your pc dmis install directory called PDFDriverInstallFiles and follow the readme file.
