2020 r2 sp3
  • 2020 r2 sp3
    Updater show me today SP3 available for 2020R2.
    Unfortunately I can't find any release notes about it... Version 15.2.313.0 from 23 November
    Anyone know something about that?
    Hi darius
    you can find the download and readme here:
    https://software.hexagonmi.com/publi...e/2020_R2/SP3/
      Release Notes - 2020 R2
      SP3
      • PCD-82062 - Fixed an issue where the Copy Parameters functionality
      didn't work properly for the Laser Edge Point features.
      • PCD-177993 - Fixed an issue where the calibration matrix for Laser probes
      didn't transform correctly and showed high standard deviation errors when the
      tool was mounted off the rotary table.
      • PCD-188259 - Fixed a software crash that occurred when you used the HP-CVE camera and the probe went to the focus position.
      • PCD-190082 - Fixed an issue with the automation interface that could cause
      the PC-DMIS application to not properly terminate.
      • PCD-194852 - Fixed an issue where PC-DMIS showed a black background in
      the DOF area of the Best Fit Alignment dialog box.
      • PCD-194853 - Fixed an issue where the DIMINFO command didn't support
      ISO local Size minimum and maximum diameters when geometric tolerance
      was set to RFS and the Feature Math option was set to default.
      • PCD-197686 - Fixed an issue where PC-DMIS didn't update the Grid Size
      value when you selected Grid Mesh and changed the Finalize Mode options
      in the Mesh Command dialog box.
      • PCD-198080 - Fixed an issue where a new custom laser scanning profile was
      added when you pressed the portable arm button to close the Laser Data
      Collection Settings dialog box after you measured an exclusion plane.
      • PCD-199754 - Improved the performance of the Geometric Tolerance
      command with large datasets.
      • PCD-200936 - Added revised rules for datums at Maximum Material
      Boundary (MMB) and Least Material Boundary (LMB) to reference higher
      precedence datums with the same material condition modifiers.
      • PCD-200965 - Fixed an issue where, instead of executing the COP/OPER,
      EXPORT command from a subroutine, PC-DMIS would display an error
      message.
      • PCD-201556 - Fixed an issue where new measurement routines couldn't send
      their file name to the HxGN SFx | Asset Management.
      • PCD-201817 - Fixed an issue where the COP command size showed zero
      after you deleted the COPIMPORT or COPEXPORT command.
      • PCD-202400 - Fixed an issue where the ESF features were drawn with the
      nominal co-ordinates instead of actual co-ordinates in the Graphic Display
      window.
      • PCD-202537 - Fixed an issue where you were not able to understand the
      interpretation of the constructed line features for the Geometric Tolerance.
      • PCD-202609 - Fixed an issue where PC-DMIS allowed you to edit the
      measured values in the Edit window for the ESF (VWMP) features.
      • PCD-202624 - Fixed an issue where PC-DMIS report showed a reduced size
      position graphic when an axis wasn't selected.
      • PCD-202832 - Fixed an issue where the Geometric Tolerance reports showed
      the zero value when you measured datum size for the preresolved datums
      with Regardless of Material Boundary (RMB) selected.
      • PCD-203342 - Fixed an issue where the GEOTOLPROFILE labels didn't
      follow the format of the Dimension command.
      • PCD-203433 - Fixed an issue where PC-DMIS showed the probe for a short
      time when you opened the Auto Features dialog box.
      • PCD-203491 - Fixed an issue where PC-DMIS didn't show arrow heads in the
      Graphic Display window.
      • PCD-203601 - Added bonus tolerance to the K0060 field for the .dfq output
      file in Q-DAS Configuration.
      • PCD-203620 - Fixed an issue where the scanning parameters were incorrect
      for the Eagle Eye Laser scanning probe.
      • PCD-203628 - Fixed an issue where PC-DMIS would hang when you used
      the Quick Feature to extract an ellipse.
      • PCD-203809 - Fixed a software crash that occurred when you selected a
      datum (pattern) and set the GD&T Standard option as ISO 1101 in the
      Geometric Tolerance dialog box.
      • PCD-204106 - Fixed a software crash that occurred when you created a
      construct feature set from the COPCLEAN command.
      • PCD-201149 - Fixed an issue where the graphical analysis didn't use the
      supplied measured vectors when you used the Geometric Tolerance
      cylindricity.
      • PCD-204302 - Fixed an issue where PC-DMIS didn't show an error message
      when decimal symbol comma didn't convert to decimal point in the Windows
      regional settings for the number formats.
      • PCD-204325 - Fixed an issue where PC-DMIS disabled the warning message
      when you selected the Use Text Mode Dimension Reporting check box in
      the Report dialog box.
      • PCD-204360 - Fixed an issue where an event was missing in the
      EventModule.xml file in the onStartingApplication command.
      • PCD-204425 - Fixed an issue where the GeoTol Position label didn't show the
      feature name when three or more axes were selected.
      • PCD-204457 - Fixed an issue where the tabs in the Best Fit Alignment dialog
      box were not displaying properly on high resolution monitors.
      • PCD-204661 - Fixed an issue where the size command was not able to
      calculate the ISO limits and tolerance when the tolerance was associated with
      an ISO 286 tolerance code.
      • PCD-204858 - Fixed a software crash that occurred when you edited the
      thickness gage dimensions from the Thickness Gage dialog box and used
      internal command suffixes in the feature names.
      • PCD-204936 - Fixed a software crash that occurred when you opened a
      measurement routine with CAD GD&T elements.
      • PCD-205468 - Fixed an issue with the geometric tolerance command when
      using a constructed BF plane that was constructed from features such as
      circles or cylinders.
      • PCD-205592 - Fixed an issue where some scanning parameters didn't work
      properly for the Eagle Eye Laser sensor.
        Impressive fix list, dev team! Keep them coming!
        PC-DMIS CAD++ 2o19 R1 SP11
