I am being told my measurement is wrong. Which I am ok with but not sure of better way to do it. the 1.3 Diminsion I am getting an out of tolance and no repetabilty. Untitled.png
told I am wrong
You are correct in your assumption. I do not know what PH is. It is not on the part. The way they tell me they want it measured is Datum B is a plane that will intersect and at the point of the 10 degree plane.
Sorry but that is nonsensical - you're being asked to measure from a feature (which does exist) to one which doesn't exist, you can't make it right or wrong, you're measuring to nothing!
It looks to me like you have a small amount of planar material around the cone. Can you get manuals on that surface, and then level to it and set it to Z+. Then take 4 hits in the cone, and call the circle created as X&Y origins (the machine will assume machine X&Y rotations, but use the circle as origin points. Then, you could use the autoplane at 1 level (basically hits in a single, circular pattern), with a whole bunch of hits and a spacer of just over the radius of the top of the cone to get the plane? I have a part similar to this that has a draft angle. The only other fix that I can think of, is to attach a plate to the surface and measure the plate, then remove the plate without disturbing the part.
Measure cone.
Measure small flat as line and intersect with cone centerline.
Measure line on 10° surface.
Dimension distance from intersection point perpendicular to line.
This needs the 7°30' to be able to be measured as a cone.PC-DMIS CAD++ 2o19 R1 SP11
by triple_zI'm having a bit of an issue checking a simple conical feature in a ring. It's a Ø4" diameter ring with a 36° I.D. lead that transitions into...
09-24-2008, 05:53 PM -
Are there any known issues with auto-feature cones and V3.7 MR3? Getting some funny values for the cone 'A'ngle.
03-15-2007, 08:35 AM -
by Sora5Would appreciate any input on how to interpret and how to have PCDMIS interpret the following position callout on the inside sphere per ASME. A is the...
11-06-2019, 02:28 PM -
by FFGOOCHI have a cylinder running at a 40 degree angle toward the center of a cone. I have measured the 4 cylinders and I am trying to get the center line of...
05-24-2019, 11:06 AM -
To all -
I am having a difficult time creating the proper point location for an intersection between a cylinder and a cone. I have a print calling...-
06-01-2010, 07:36 PM -
