Per Renishaw, the medium force TP20 is good for up to 60mm; however, depending on your part and tolerances, you could do some experiments with a ring gage and gage block to see if the 75mm gives you good numbers. I would expect that you would need to slow down the move speed as well as the touch speed.
HTH ☺
7107 Global Classic TP20
2019R1 SP1 CAD++
I have a part that uses a similar sized styii with an extended force module . Standard Deviations usually are running around 12 to 15 microns. Probe is qualified at A90B90 and A90B-90. Want to use my scanning probe but it has not been validated yet. My understanding is that the scanning probe can handle bigger and long styli.
What scanning probe do you have?
I have one build on our Leitz scanning probe that uses an 8x75 stylus with a 150 carbon fiber extension. I can't run it faster than 200 mm/sec due to the weight and false triggers, but it works well and is very repeatable.
Has anyone used, or does anyone use a gram gauge to set the proper triggering speed. And does anyone know a good way to figure out the optimum trigger...
I have started noticing a lot of false triggers when the CMM moves in 'Z'. It seems to happen not matter which of my TP20 modules is being used (9 module...
Is there a way inside my program to set the triggering force I am using a tp2 30mm ext 4x20mm styli. The wieght of the extension is making it trigger...
