weight balance routine timed out (how often do you get that ?)
  • weight balance routine timed out (how often do you get that ?)
    Hi,
    I'm trying to understand where does this issue come from.
    We have 2 cmm et we've never had this message on the oldest (almost 3 years old).
    Could it be an issue with the head ?
    We had a crash but the problem started before the crash.
    I also noticed presence of dust iron on the magnets (both head and styli), it was better after cleaning.
    But sometimes the head lags (it stands still a few seconds, not reaching the time out but close enough)
    When it reaches the time out we're screwed... because the CMM is used on an atomation production line...
    The head is an analog HP-S-X1C
    Thanks
    Hi,
    Both cmm are Tigo ?
    Maybe there's a setting which is different between them (I don't know about fixed head, except LSPX5, but I don't remember a parameter like this...)
      Yes 2 tigo.
      I've heard of a parameter named "wristLockDelay" but is it only for rotating heads ?
        Depends on the controller, in the constant.dat, there's a parameter called CTR_CTO, control contact timeout...
        You can check if the values are the same ?
          is it available via 100.0.0.1 ?
          didn't find the file constant.dat
