Need help with setting of how to calibrate of Cylinder probe. Please!!!
  • Need help with setting of how to calibrate of Cylinder probe. Please!!!
    The Print does call out an ID thread as a datum A.
    I would like to use the square end cylinder probe to pick up an Id thread (cylinder) for my datum A, something i never done before.
    Can you help me how to set it to calibrate.
    M2 Ø3 mm silver steel cylinder, L 12.75 mm
    Thank you in advance.
    I can't stress enough to you how much I DO NOT recommend using shank probes. IME they've been nothing but garbage and a lot of my colleagues will say the same.
    Would recommend you use an autocircle or autocylinder and use the pitch option in the dialogue box when setting up the feature. I do this a lot, is repeatable for location but not so much size.
      Thank you,
