Linear Closed Scan
  • Linear Closed Scan
    I am doing a linear closed scan on ID square cutout. The problem is that when the probe comes to the corners it does a few weird moves that puts the surface profile out of tolerance. Is there a way to fix this or is there a way to delete the points in the corners and skip over the corners all together and still be able to keep scanning?.
    Maybe use 4 linear open scans ?
    I don't think you can scan accurately corners, because the stylus ball doesn't goes in, so the radius compensation cannot be right.
      OD, outside corner....
      If is IS some sort of a 'true' square profile, as in, 4 lines, just measure lines. Otherwise you will have to do 4 linear open scan, one on each edge.
        • Matthew D. Hoedeman
          Matthew D. Hoedeman commented
          I guess I can't read today. Would have swore is said OD....
        https://www.pcdmisforum.com/core/image.php?userid=11&thumb=1&dateline=1450808418
        #4.1
        Today, 05:51 PM
        Matthew D. Hoedeman : It's complicated enough for me to understand the abbreviations (and English in general!), please don't add more !!!!!
          Make 4 separate linear open scans.
          Create one featureset out of the 4 scns. Hardcode it so PCD looks at all of the points from the scans.
          Do your usual dimensional output, but on the featureset itself.
          SCN1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$
          NOM/XYZ,<-8.1,-12.8,-4.35>,$
          MEAS/XYZ,<-8.1,-12.8,-4.35>,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>
          SCN2 =GENERIC/POINT,DEPENDENT,CARTESIAN,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>
          SCN3 =GENERIC/POINT,DEPENDENT,CARTESIAN,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>
          SCN4 =GENERIC/POINT,DEPENDENT,CARTESIAN,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>
          SCN5 =FEAT/SET,CARTESIAN
          THEO/<-8.1,-12.8,-4.35>,<0,-1,0>
          ACTL/<-8.1,-12.8,-4.35>,<0,-1,0>
          CONSTR/SET,BASIC,SCN1.HIT[1..SCN1.NUMHITS],SCN2.HIT[1..SCN2.NUMHITS],SCN3.HIT[1..SCN3.NUMHITS],SCN4.HIT[1..SCN4.NUMHITS],,
          DIM PROF1= PROFILE OF SURFACE OF SET SCN5 FORMANDLOCATION UNITS=IN ,$
          GRAPH=OFF TEXT=OFF MULT=10.00 ARROWDENSITY=100 OUTPUT=BOTH
          M 0.00000 0.00000 0.00200 0.00200 0.00000 0.00000 ----|----
          ANALYSISVIEW/PROF1,,
          • JEFMAN
            JEFMAN commented
            Just a attention on the form, it doesn't work without cad or theo values...
          • DAN_M
            DAN_M commented
            Yes correct, I just made generic points and called them "SCN"s and put them all at the same XYZ value because I did it quickly, real data would need actual XYZIJK values, hopefully he/she got my point
          A simpleton like myself... when I get nasty corners... I use freeform scan and delete the hits which can't make clean hits due to required tip size...and combine as a feature set.
          I don't know if the OP is using tactile or analog. anyway, the suggestion is just another condiment for the profile burger
