2020 R2 Profile issue. What's going on here?
  • 2020 R2 Profile issue. What's going on here?
    I have an MBD part I'm converting to R2 (removing legacy profile and adding GeoTol). I have a profile that is .010 to no datums (form profile) that I'm having issues with. The surface in question is the surface that the datum B target points are on but the datum B points are not being profiled. When I make the profile, it gives me the error in the code below. The surface is NOT planer so I decided to try constructing a plane and profiling that. The plane works but it is telling me the profile is out while the entire program is at nominal (program executed offline to zero everything out). Anyone have an idea what's going on here?
    I have included the datums and definitions although it shouldn't matter because the profile is to no datums. I also have the plane and scan constructions there too. The dimensions at the bottom, 30A is profiling the plane and 30B is dimensioning the scan. Keep in mind, all feature actuals are nominal, its like the program has never run.
    Edited to add that the surface is NOT planer. Don't know how I missed that. That explains the deviation in DIM 30A. Still have no idea why it isn't liking the scan.
    Capture.JPGhttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==‚Äč
    DATUM_C =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<1.4937,0,0.0648>,<0,1,0>
    ACTL/<1.4937,0,0.0648>,<0,1,0>
    TARG/<1.4937,0,0.0648>,<0,1,0>
    SNAP=NO
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    AVOIDANCE MOVE=NO,DISTANCE=0.1
    SHOW HITS=NO
    MOVE/CLEARPLANE
    TIP/T1A97.5B-90, SHANKIJK=0.9914, 0, -0.1305, ANGLE=-89.9997
    CLEARP/XPLUS,2.7,XPLUS,0,OFF
    MOVE/CLEARPLANE
    DAT_A1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<1.2677,-0.3633,0>,<0,0,-1>
    ACTL/<1.2677,-0.3633,0>,<0,0,-1>
    TARG/<1.2677,-0.3633,0>,<0,0,-1>
    SNAP=NO
    SHOW HITS=NO
    DAT_A2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<0.196,-0.4964,0>,<0,0,-1>
    ACTL/<0.1961,-0.4964,0>,<0,0,-1>
    TARG/<0.196,-0.4964,0>,<0,0,-1>
    SNAP=NO
    SHOW HITS=NO
    DAT_A3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<1.1967,-3.1338,0>,<0,0,-1>
    ACTL/<1.1967,-3.1338,0>,<0,0,-1>
    TARG/<1.1967,-3.1338,0>,<0,0,-1>
    SNAP=NO
    SHOW HITS=NO
    DATUM_A =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
    THEO/<0.8868,-1.3312,0>,<0,0,-1>
    ACTL/<0.8868,-1.3312,0>,<0,0,-1>
    CONSTR/PLANE,BF,DAT_A1,DAT_A2,DAT_A3,,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,WAVELENGTH=0
    MOVE/CLEARPLANE
    MOVE/INCREMENT,<-0.0001,-0.0001,9>
    TIP/T1A15B-90, SHANKIJK=0.2588, 0, 0.9659, ANGLE=-89.9999
    CLEARP/ZPLUS,2,ZPLUS,0,OFF
    MOVE/CLEARPLANE
    DAT_B1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<2.1261,-2.7411,0.565>,<0.9995989,-0.028296,-0.0011906>
    ACTL/<2.1261,-2.7411,0.565>,<0.9995989,-0.028296,-0.0011906>
    TARG/<2.1261,-2.7411,0.565>,<0.9995989,-0.028296,-0.0011906>
    SNAP=NO
    SHOW HITS=NO
    DAT_B2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<2.0422,-5.7479,0.565>,<0.9993252,-0.0273294,0.0245389>
    ACTL/<2.0422,-5.7479,0.565>,<0.9993252,-0.0273294,0.0245389>
    TARG/<2.0422,-5.7479,0.565>,<0.9993252,-0.0273294,0.0245389>
    SNAP=NO
    SHOW HITS=NO
    DATUM_B =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<2.1261,-2.7411,0.565>,<-0.0278712,-0.9996115,0>
    ACTL/<2.1261,-2.7411,0.565>,<-0.0278712,-0.9996115,0>
    CONSTR/LINE,BF,2D,DAT_B1,DAT_B2,,
    DATDEF/A,FEATURES=DATUM_A,,
    DATDEF/B,FEATURES=DATUM_B,,
    DATDEF/C,FEATURES=DATUM_C,,
    SCN30 =FEAT/SET,CARTESIAN
    THEO/<2.0854,-4.3091,0.66>,<0,0,1>
    ACTL/<2.0854,-4.3091,0.66>,<0,0,1>
    CONSTR/SET,BASIC,PNT135,PNT136,PNT137,PNT138,PNT139,PNT14 0,PNT141,PNT142,PNT143,PNT144,PNT145,PNT146,PNT147 ,PNT148,PNT149,PNT150,PNT151,PNT152,PNT153,PNT154, PNT155,PNT156,PNT157,PNT158,PNT159,PNT160,,
    PLN30 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
    THEO/<2.0854,-4.3091,0.66>,<0.9996067,-0.0280423,0.0000792>
    ACTL/<2.0854,-4.3091,0.66>,<0.9996067,-0.0280425,0.0000791>
    CONSTR/PLANE,BF,PNT135,PNT136,PNT137,PNT138,PNT139,PNT140 ,PNT141,PNT142,PNT143,PNT144,PNT145,PNT146,PNT147, PNT148,PNT149,PNT150,PNT151,PNT152,PNT153,PNT154,P NT155,PNT156,PNT157,PNT158,PNT159,PNT160,,
    30A =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    DISPLAY_COORDS=DRF,
    UNITS=IN,OUTPUT=BOTH,ARROWDENSITY=100,
    SEGMENT_1,PROFILE_SURFACE,0.01,__,<dat>,<dat>,<dat >,TOL_ZONE_MATH=DEFAULT,
    TEXT=OFF,CADGRAPH=OFF,REPORTGRAPH=OFF,MULT=100,
    MEASURED:
    PLN30:0.0158,
    ADD
    FEATURES/PLN30,,
    30B =GEOMETRIC_TOLERANCE/STANDARD=ASME Y14.5,SHOWEXPANDED=YES,
    DISPLAY_COORDS=DRF,
    UNITS=IN,OUTPUT=BOTH,ARROWDENSITY=100,ITERATEANDRE PIERCECAD=YES,
    MEASURED:
    SCN30: Freeform feature(s) need(s) points in more places to fit uniquely.
    ADD
    FEATURES/SCN30,,
    Just shooting from the hip here... Maybe it errors out because there are no deviations at all in the feature set? Feature set might be interpreted as "freeform" since a set isn't a feature per se?
    If you measure a part, does it still error out?
    PC-DMIS CAD++ 2o19 R1 SP11
      Are your THEO and ACTL values supposed to be off from <1, 0, 0> on PLN30? Perhaps the points used for construction don't fall on a plane, nominally speaking? I would check all nominal values.
      • A-machine-insp
        A-machine-insp commented
        JacobCheverie Will do. It's running now so we shall soon see. It's not a big part so it should be done fairly quickly. One thing I'm going to try, out of curiosity, is convert it back to an R1 program to see if I get the same error. The program was originally all legacy profiles and we are changing everything over to GeoTol. I wonder if Xact will give the same error. I don't think it will but I'm going to try anyways.
      • A-machine-insp
        JacobCheverie After the initial run, I still have the error. I went back and added 12 more points so I now have 39 points in an area roughly 1.2 x 3.8 inches. Ran the extra points, added it to the scan, re executed the scan... same error. I think I'm going to do a form only legacy profile so I can get the part out and revisit this later today. I am going to now go ahead and convert it back to an R1 program and see what I get. I am guessing Xact won't give me the error.
        I'm not complaining about the error at all, am fairly sure it is something I am doing wrong. I just want to know what it is and how to fix it so I can make changes in my programming style for future parts.
      • JacobCheverie
        JacobCheverie commented
        A-machine-insp Can you show the code for a few of your points in the set? Is the feature a very large radius?
        https://docs.hexagonmi.com/pcdmis/20...d_warnings.htm
      I haven't measured it yet. I am still updating the program. I will have it on the machine here in a few minutes. I'll report back when I get it ran and I will keep dimension 30A and 30B in there for S&G's.
        @JacobCheverie This is the code for all the points in the original scan. This is not including the additional 12 points I had in here. I saved the program as a test program with the additional points before I took them back out.
        PNT135 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0371,-6.3393,0.2559>,<0.998857,-0.0243433,0.0411339>
        ACTL/<2.0368,-6.3395,0.2549>,<0.998857,-0.0243433,0.0411339>
        TARG/<2.0371,-6.3393,0.2559>,<0.998857,-0.0243433,0.0411339>
        SNAP=NO
        SHOW HITS=NO
        PNT136 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0345,-6.3022,0.3452>,<0.9989804,-0.025152,0.0374914>
        ACTL/<2.0341,-6.3025,0.3443>,<0.9989804,-0.025152,0.0374914>
        TARG/<2.0345,-6.3022,0.3452>,<0.9989804,-0.025152,0.0374914>
        SNAP=NO
        SHOW HITS=NO
        PNT137 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0329,-6.2479,0.429>,<0.9990889,-0.0259156,0.0339079>
        ACTL/<2.0322,-6.2481,0.4281>,<0.9990889,-0.0259156,0.0339079>
        TARG/<2.0329,-6.2479,0.429>,<0.9990889,-0.0259156,0.0339079>
        SNAP=NO
        SHOW HITS=NO
        PNT138 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.033,-6.1694,0.4879>,<0.9991675,-0.026468,0.0310436>
        ACTL/<2.0328,-6.1695,0.4869>,<0.9991675,-0.026468,0.0310436>
        TARG/<2.033,-6.1694,0.4879>,<0.9991675,-0.026468,0.0310436>
        SNAP=NO
        SHOW HITS=NO
        PNT139 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.036,-5.8635,0.6977>,<0.9993826,-0.0284248,0.0206525>
        ACTL/<2.0352,-5.8633,0.6968>,<0.9993826,-0.0284248,0.0206525>
        TARG/<2.036,-5.8635,0.6977>,<0.9993826,-0.0284248,0.0206525>
        SNAP=NO
        SHOW HITS=NO
        PNT140 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0429,-5.5124,0.9264>,<0.9994912,-0.0305198,0.0092689>
        ACTL/<2.0412,-5.5124,0.9255>,<0.9994912,-0.0305198,0.0092689>
        TARG/<2.0429,-5.5124,0.9264>,<0.9994912,-0.0305198,0.0092689>
        SNAP=NO
        SHOW HITS=NO
        PNT141 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0484,-5.5957,0.4855>,<0.9993014,-0.0267037,0.0261465>
        ACTL/<2.0486,-5.5956,0.4845>,<0.9993014,-0.0267037,0.0261465>
        TARG/<2.0484,-5.5957,0.4855>,<0.9993014,-0.0267037,0.0261465>
        SNAP=NO
        SHOW HITS=NO
        PNT142 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0456,-5.9822,0.2613>,<0.9989839,-0.0245629,0.0377875>
        ACTL/<2.0456,-5.9821,0.2603>,<0.9989839,-0.0245629,0.0377875>
        TARG/<2.0456,-5.9822,0.2613>,<0.9989839,-0.0245629,0.0377875>
        SNAP=NO
        SHOW HITS=NO
        PNT143 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0667,-5.1431,0.2512>,<0.9992173,-0.0248434,0.0307825>
        ACTL/<2.0668,-5.1431,0.2503>,<0.9992173,-0.0248434,0.0307825>
        TARG/<2.0667,-5.1431,0.2512>,<0.9992173,-0.0248434,0.0307825>
        SNAP=NO
        SHOW HITS=NO
        PNT144 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0605,-5.0787,0.5699>,<0.9994449,-0.0276439,0.0185909>
        ACTL/<2.0604,-5.0785,0.5689>,<0.9994449,-0.0276439,0.0185909>
        TARG/<2.0605,-5.0787,0.5699>,<0.9994449,-0.0276439,0.0185909>
        SNAP=NO
        SHOW HITS=NO
        PNT145 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0592,-4.9783,0.9443>,<0.999515,-0.0308693,0.0041117>
        ACTL/<2.059,-4.9782,0.9434>,<0.999515,-0.0308693,0.0041117>
        TARG/<2.0592,-4.9783,0.9443>,<0.999515,-0.0308693,0.0041117>
        SNAP=NO
        SHOW HITS=NO
        PNT146 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0723,-4.6567,0.5635>,<0.9994995,-0.0277442,0.0151959>
        ACTL/<2.0723,-4.6567,0.5626>,<0.9994995,-0.0277442,0.0151959>
        TARG/<2.0723,-4.6567,0.5635>,<0.9994995,-0.0277442,0.0151959>
        SNAP=NO
        SHOW HITS=NO
        PNT147 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0805,-4.292,0.9427>,<0.9995156,-0.0310793,-0.001594>
        ACTL/<2.0802,-4.2919,0.9419>,<0.9995156,-0.0310793,-0.001594>
        TARG/<2.0805,-4.292,0.9427>,<0.9995156,-0.0310793,-0.001594>
        SNAP=NO
        SHOW HITS=NO
        PNT148 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0869,-4.336,0.2534>,<0.9994035,-0.0251701,0.0236468>
        ACTL/<2.0868,-4.3357,0.2525>,<0.9994035,-0.0251701,0.0236468>
        TARG/<2.0869,-4.336,0.2534>,<0.9994035,-0.0251701,0.0236468>
        SNAP=NO
        SHOW HITS=NO
        PNT149 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.0929,-3.9144,0.5843>,<0.9995706,-0.0281626,0.0080954>
        ACTL/<2.0927,-3.9143,0.5834>,<0.9995706,-0.0281626,0.0080954>
        TARG/<2.0929,-3.9144,0.5843>,<0.9995706,-0.0281626,0.0080954>
        SNAP=NO
        SHOW HITS=NO
        PNT150 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1067,-3.446,0.916>,<0.999487,-0.0310842,-0.0077139>
        ACTL/<2.1054,-3.4458,0.9151>,<0.999487,-0.0310842,-0.0077139>
        TARG/<2.1067,-3.446,0.916>,<0.999487,-0.0310842,-0.0077139>
        SNAP=NO
        SHOW HITS=NO
        PNT151 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1091,-3.4456,0.2727>,<0.9995558,-0.0256204,0.015225>
        ACTL/<2.1092,-3.4454,0.2717>,<0.9995558,-0.0256204,0.015225>
        TARG/<2.1091,-3.4456,0.2727>,<0.9995558,-0.0256204,0.015225>
        SNAP=NO
        SHOW HITS=NO
        PNT152 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1144,-3.1536,0.5648>,<0.9995996,-0.0282014,0.0023138>
        ACTL/<2.1144,-3.1536,0.564>,<0.9995996,-0.0282014,0.0023138>
        TARG/<2.1144,-3.1536,0.5648>,<0.9995996,-0.0282014,0.0023138>
        SNAP=NO
        SHOW HITS=NO
        PNT153 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1219,-3.0712,1.1528>,<0.9992664,-0.0331224,-0.0192216>
        ACTL/<2.1198,-3.0714,1.152>,<0.9992664,-0.0331224,-0.0192216>
        TARG/<2.1219,-3.0712,1.1528>,<0.9992664,-0.0331224,-0.0192216>
        SNAP=NO
        SHOW HITS=NO
        PNT154 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.13,-2.8996,1.2584>,<0.9991244,-0.0340168,-0.0243579>
        ACTL/<2.128,-2.8994,1.2576>,<0.9991244,-0.0340168,-0.0243579>
        TARG/<2.13,-2.8996,1.2584>,<0.9991244,-0.0340168,-0.0243579>
        SNAP=NO
        SHOW HITS=NO
        PNT155 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1382,-2.6986,1.3073>,<0.9990219,-0.0344485,-0.027721>
        ACTL/<2.1363,-2.6985,1.3066>,<0.9990219,-0.0344485,-0.027721>
        TARG/<2.1382,-2.6986,1.3073>,<0.9990219,-0.0344485,-0.027721>
        SNAP=NO
        SHOW HITS=NO
        PNT156 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1464,-2.4644,1.312>,<0.9989598,-0.0345221,-0.0297907>
        ACTL/<2.1439,-2.4645,1.3113>,<0.9989598,-0.0345221,-0.0297907>
        TARG/<2.1464,-2.4644,1.312>,<0.9989598,-0.0345221,-0.0297907>
        SNAP=NO
        SHOW HITS=NO
        PNT157 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1275,-2.7516,0.846>,<0.9994693,-0.0306506,-0.011027>
        ACTL/<2.1267,-2.7514,0.8451>,<0.9994693,-0.0306506,-0.011027>
        TARG/<2.1275,-2.7516,0.846>,<0.9994693,-0.0306506,-0.011027>
        SNAP=NO
        SHOW HITS=NO
        PNT158 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1367,-2.4616,0.8684>,<0.9994215,-0.0308887,-0.0142308>
        ACTL/<2.135,-2.4615,0.8676>,<0.9994215,-0.0308887,-0.0142308>
        TARG/<2.1367,-2.4616,0.8684>,<0.9994215,-0.0308887,-0.0142308>
        SNAP=NO
        SHOW HITS=NO
        PNT159 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1257,-2.7634,0.4054>,<0.9996264,-0.0269351,0.0046436>
        ACTL/<2.1257,-2.7633,0.4046>,<0.9996264,-0.0269351,0.0046436>
        TARG/<2.1257,-2.7634,0.4054>,<0.9996264,-0.0269351,0.0046436>
        SNAP=NO
        SHOW HITS=NO
        PNT160 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<2.1343,-2.4698,0.2592>,<0.9996419,-0.0257476,0.007294>
        ACTL/<2.133,-2.4698,0.2584>,<0.9996419,-0.0257476,0.007294>
        TARG/<2.1343,-2.4698,0.2592>,<0.9996419,-0.0257476,0.007294>
        SNAP=NO
        SHOW HITS=NO
        ACTL/<2.0847,-4.3091,0.6592>,<0,0,1>
        ACTL/<2.0847,-4.3091,0.6592>,<0.9996082,-0.0279403,0.0016641>
          A-machine-insp Very odd, I put your points into PC-DMIS and it took the profile just fine. At first, my set wasn't in the correct order and it gave me the same error. I reordered and it was fine. You have some spaces in your CONSTR/SET line (Ex: PNT14 0). Are those artifacts of copying your code onto here?
          • A-machine-insp
            neil.challinor I will speak with my boss again (hopefully today but no guarantee) and see what he says.
          • A-machine-insp
            neil.challinor I sent you a message.
          • JacobCheverie
            neil.challinor I manually created Auto Vector Point features with the same nominal values. When I select the points in order (135, 136, 137, ...) in the feature set I have no problem reporting profile of 0. As soon as I switch the order (..., 157, 158, 160, 159) I receive the error.
          Have you tried reconstructing the set from scratch and recreating the Geometric Tolerance command?
          • A-machine-insp
            I have not but I will do that first when I get back into it today.
          Just out of interest, were the points picked from the CAD model or were they taught via the jogbox on the machine? Looking at the co-ordinates and vectors makes me think they were taught via the jogbox which might be the problem. If the nominal X,Y,Z,I,J,K are not correct then that would account for the error message and also explain the deviation on your constructed plane.
          Neil Challinor
          PC-DMIS Product Owner
          E: [email protected]
          I think there is something wrong with this program. I mirrored the part to check the opposite hand (exact mirrored opposite), executed the program offline to make all features nominal, then checked the report. All of my true positions and profiles are OOT .050"-.100". I'm looking into the program now to see if I can find the issue.
          EDIT: I ended up deleting the mirrored program and re mirroring it and it worked this time. I guess I just caught DMIS at a bad moment. The profile is still not liking me though.
