They don't stop !!!!!!!
https://www.wilcoxassoc.com/public/P...20_R1/SP8/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP8/x64/
Release Notes - 2020 R1
SP8
• PCD-177993 - Fixed an issue where the calibration matrix for Laser probes
didn't transform correctly and showed high standard deviation errors when the
tool was mounted off the rotary table.
• PCD-185747 - Fixed an issue where PC-DMIS took more time to export a
pointcloud file than usual when you exported a psl file.
• PCD-188653 - Fixed an issue where the On Error command couldn't skip
the current command when you worked with the Leica LMF interface.
• PCD-194875 - Fixed an issue where PC-DMIS didn't create annotation points
to a selected CAD face for a Point Colormap when you marked the Create
annotation points check box in the Pointcloud Operator dialog box.
• PCD-195832 - Added the new names for TesastarMP US components and
support for the 6-way module.
• PCD-197686 - Fixed an issue where PC-DMIS didn't update the Grid Size
value when you selected Grid Mesh and changed the Finalize Mode options
in the Mesh Command dialog box.
• PCD-198080 - Fixed an issue where a new custom laser scanning profile was
added when you pressed the portable arm button to close the Laser Data
Collection Settings dialog box after you measured an exclusion plane.
• Fixed an issue where, instead of executing the COP/OPER, EXPORT
command from a subroutine, PC-DMIS would display an error message.
• PCD-201313 - Added definitions for the HP-Te series of probes.
• PCD-201581 - Fixed an issue where the generic features were highlighted in
the Graphic Display window after the execution of a measurement routine.
• PCD-202002 - Fixed an issue where the vision features had an incorrect
calibration when you used the illumination override on a feature.
• PCD-202580 - Fixed a software crash that occurred when you calibrated the
CWS probe from the probe calibration toolbox.
• PCD-202759 - Fixed a software crash that occurred when you clicked OK in
the Thickness Gage dialog box after you edited the Point of Interest for the
command.
• PCD-203142 - Fixed a software crash that occurred when you clicked Apply
in the Animated Probe Changer dialog box.
• PCD-203163 - Fixed a software crash that occurred when you executed
thickness scans.
• PCD-203246 - Fixed an issue where the Vision 2D distortion compensation
was not active when the execution was started after a first magnification
change.
SP8
command.
thickness scans.
change.
