sample hits
  • sample hits
    Hi all
    Does sample hits (using 3 points) override the vector/direction of 3D-features?
    I.e. if i take 3 sample hits for a cylinder, will the cylinder have the vector of the sample hits or from the centerline of cylinder?
    So if I wanna evaluate an angle between a plane and a cylinder with sample hits. would it dimension the angle between the plane - sample hits, or plane - center line of cylinder?
    The sample hits (for a cylinder) set the measuring vector but the result vector will be the hits in the cylinder, sample hits are 'reference' hits, so it will use the C/L of the cylinder
    • pcdmisstudent
      pcdmisstudent commented
      so the 3 sample hits are basically just an alignment?
      And what if theres no "real plane" and the surface is curved. Will the 3 points just act like a bf plane?
    • Matthew D. Hoedeman
      Matthew D. Hoedeman commented
      3 points can always make a plane. The purpose of the sample hits are:
      For determining the depth and initial vector of the feature.
      Circles, cylinders, SURFACE points (and probably others) can have sample hits. For the circles & cylinders, they are used as above (depth and vector) for SURFACE points they are used for the check vector of the surface point. A little overkill for SURFACE points IMO unless you are dealing with micron tolerances.
    • pcdmisstudent
      Oh okay: So if using sample hits on cylinder it "overrides" the initial nominal vector from the CAD's nominal value?
      And in other words, its not good to use for holes on curved surfaces like a hole drilled thru a spherical object?
      Or im i just noob at vectors
    SAMPLE HITS. This is a function that was originally put in for SHEET METAL MEASUREMENTS because sheet metal (and plastics) are all but impossible to hold to correct form.
    1 sample hit:
    This will ONLY allow you to set a specific depth of measurement, it will not use anything but the THEO vectors.
    3 sample hits:
    This will allow you to both set a specific depth of measurement and a TEMPORARY vector to measure the feature at. Mostly useful for hole in thin stock part. Not really something that should be used for BLOCK type parts, as in MACHINED details.
    EDGE POINTS can have up to 5 sample hits or as few as 1, the number of sample hits changes WHAT is sampled.
    For a block-type part and measuring a cylinder, I would use ONLY 1 sample hit so you can control the depth for the 'top' ring of hits. Same deal for a hole drilled in a spherical object, you set WHERE the sample hit is going to be (by the start/end angles) so that it will hit in the 'lowest' area and thus give you a ring of hits for the circle that do not skip over the top of the part.
    • pcdmisstudent
      Thanks matty
      i wondered because i evaluated the plane against cylinder drilled thru a big radius, and then same plane with same cylinder +3 sample hits, and the result varied 0.5mm
    and the result was better with 3 sample hits
    • dwade
      sample hits
      by dwade
      Can I pull sample hits from an autocircle? I've looked and looked and cannot find out how to do it. I can pull the individual hits from the cirlces but...
      12-19-2007, 11:38 AM
    • kmcmm
      sample hits
      by kmcmm
      Hey guys,
      this may sound like a easy question, but I am new to programming automotive stampings with pc-dmis. I used to program medical devices...
      06-05-2006, 09:16 PM
    • Stephen1055
      Turn off hits in cylinder
      by Stephen1055
      Is it possible to turn off some of the hits in a cylinder?
      I'd like to create a cylinder that measures from 0 to 180 at one z-level and...
      10-07-2015, 04:13 PM
    • keego
      Sample Hits and Spacer
      by keego
      I'm trying to use sample hits on an autocircle but am having problems. I have my z for the circ at -5 and my spacer set to 4. It takes the sample hits...
      10-16-2009, 08:34 AM
    • Ken8282
      learning to measure a Cylinder
      by Ken8282
      When I create a cylinder from touch mode. As it runs in DCC from point to point the probe drifts in one direction or the other in the Z axis. I have a...
      11-27-2012, 04:13 PM
