2020 R2 Sp2...... !
  • 2020 R2 Sp2...... !
    https://www.wilcoxassoc.com/public/P...20_R2/SP2/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R2/SP2/x64/
    Release Notes - 2020 R2
    SP2
    • PCD-168144 - Fixed an issue where the area scan didn't consider the new
    alignment when you moved the part and machine for the ATS600 tracker.
    • PCD-187629 - Fixed an issue where the paste operation didn't work properly
    when you copied the measurement sequence from one measurement routine
    into another.
    • PCD-188653 - Fixed an issue where the On Error command couldn't skip
    the current command when you worked with the Leica LMF interface.
    • PCD-195832 - Added the new names for TesastarMP US components and
    support for the 6-way module.
    • PCD-199838 - Fixed an issue where the previous scan regions were shown in
    the Overview Camera when you inserted a new area scan for the ATS600
    Tracker.
    • PCD-201313 - Added definitions for the HP-Te series of probes.
    • PCD-201581 - Fixed an issue where the generic features were highlighted in
    the Graphic Display window after the execution of a measurement routine.
    • PCD-201880 - Fixed an issue where the bitmap was corrupted when you
    printed report to 3D PDF.
    • PCD-202002 - Fixed an issue where the vision features had an incorrect
    calibration when you used the illumination override in a feature.
    • PCD-202546 - Fixed an issue where you were not able to edit the theoretical
    values of the constructed width features in the Construct Width dialog box.
    • PCD-202580 - Fixed a software crash that occurred when you calibrated the
    CWS probe from the probe calibration toolbox.
    • PCD-202759 - Fixed a software crash that occurred when you clicked OK in
    the Thickness Gage dialog box after you edited the point of interest for the
    command.
    • PCD-202850 - Fixed an issue where the report showed the incorrect size
    modifier for the form and runout tolerances when you reported ISO
    straightness of a cylinder.
    • PCD-203046 - Fixed an issue where PC-DMIS didn't allow selection of
    multiple slots when you selected the Datum Definition dialog box from the
    menu item.
    • PCD-203142 - Fixed a software crash that occurred when you clicked Apply
    in the Animated Probe Changer dialog box.
    • PCD-203163 - Fixed a software crash that occurred when you executed
    thickness scans.
    • PCD-203164 - Fixed an issue where PC-DMIS showed an error message
    when you did parallelism of a 2D line to an axial datum.
    • PCD-203218 - Fixed an issue where PC-DMIS showed an error message
    when you used a mid-line whose two input lines were at different heights.
    • PCD-203246 - Fixed an issue where the Vision 2D distortion compensation
    was not active when the execution was started after a first magnification
    change.
    • PCD-203293 - Fixed an issue where the Report Output check box was
    automatically deselected in the Output Configuration dialog box when you
    clicked the Print Full Report button in the marked sets window.
    • PCD-203458 - Fixed an issue where the 1D width was incorrectly allowed as
    a secondary datum.
    • PCD-203610 - Fixed an issue where PC-DMIS showed an error message for
    some cases of lower-precedence 2D datums when you created a 3D BF or
    BFRE constructed line.
    • PCD-203642 - Added the date and time stamps to the DME log file for the I++
    server.
    • PCD-203814 - Increased UZ offset limit to 200% of the total tolerance for the
    ISO profile to support the ultra-unilateral profile tolerance.
    Impressive and fast, right on the heels of SP1!
    Noone will ever criticize you for releasing fast fixes, quite the contrary!
    Kudos to the devteam and testers!
    PC-DMIS CAD++ 2o19 R1 SP11
      Still no fix for the new geometric tolerance showing the data on text only reports though.
      DeWain Hodge
        Maybe its time to navigate away from text only reports??
          As soon as the new reporting gets as editable as a text only report.
          DeWain Hodge
