display circle scan profile on dimensional report
  • display circle scan profile on dimensional report
    After performing a circular scan, how do I display the profile of the scan on the dimensional report
    Really don't understand your question. A graphical representation? The measured values?
    7107 Global Classic TP20
    2019R1 SP1 CAD++
      how can I display the graphical analysis of a circular scan on the dimensional report?
        I use the analysisview command. You can just type "analysisview" into the edit window then F9 it and select the scan you want to display and press the Show All Arrows button. From there you can adjust how you want it to look.
          Several different ways. Turn GRAPH to ON. Change MULT to say 100 or whatever makes the arrows show up well on the screen. Then you can click snapshot. Or you can Insert / Report Command / Analysis. Or you can Insert / Report Command / Screen Capture.
          2019R1 SP1 CAD++
            In the Reporting Tab, you can turn ON graphical analysis. Otherwise, after the dimension go to Insert-Report Command-Analysis and the select the dimension to add to the report. The second option, you can change views and other items to make it more presentable.
            Update: What they said above...I was late to the game.
