I am a instructor at Plam Beach CC learning how to program and run a simple block form student project. My question is how do we program to check a 1/4-20 threaded hole? I am using 10 hits for diameter and position. I am thinking I should measure as a cylinder with even more hits to get enough points on the thread helix to establish position.
Threaded holes
Use a cylinder, use 2 levels with 5 hits per level and enter .05 (1 divided by 20) for the pitch. The distance between your depth and height (the two rows of your cylinder) should be a multiple of the pitch. (example: hole is .5 deep with .4 thread, set depth @ .1 and height @ .3. The difference of .3-.1 = .2 which is = .05 x 4) I do this all time and it works well.HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by Wes Cisco View PostYou can, but if the hole was hand tapped crooked . . .
Originally posted by cmmguy View PostThe hand tap will only follow the minor diameter which is created using the drilled hole. Now if that is crooked...sigpic
Originally posted by cmmguy View PostThe hand tap will only follow the minor diameter which is created using the drilled hole. Now if that is crooked...sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by Wes Cisco View PostUse a cylinder, use 2 levels with 5 hits per level and enter .05 (1 divided by 20) for the pitch. The distance between your depth and height (the two rows of your cylinder) should be a multiple of the pitch. (example: hole is .5 deep with .4 thread, set depth @ .1 and height @ .3. The difference of .3-.1 = .2 which is = .05 x 4) I do this all time and it works well.HTHKevin
Originally posted by Matthew D. Hoedeman View PostNaw, you can get the tap to go in skewed to the drilled hole, if you are hand tapping. I have seen it, I have done it. Usually (but not always) it will also break the tap, but it can be done.Originally posted by Wes Cisco View PostWell that depends on if the tap is started straight and whether or not the gorilla spinning the tap uses a center, or even gives a chit. I have seen straight holes tapped quite crooked. Never underestimate the ability of the primates... But by and large if your machinist are worthy of the title, then an autocircle will suffice.
Metric is well... metric.
Originally posted by cmmguy View PostOk, if you predrill the hole and are able to start and tap crooked... how is the CMM going to pickup anything other that the minor diameter(predrilled hole) anyway??? You would need to use a thread locator if tapping the hole crooked is a problem.
Pitch is the distance from crest to crest or root to root whether English/Standard or Metric. I do not do a lot of metric work, so to find the pitch if it is not on the print I would pull out Machinery's Handbook.
my .02- i would teach students to just use the circle feature using maybe a 3mm ball & 4 or 5 hits to check the location of 1/4-20 tapped holes. on a cmm the simpler the geometry the better. when you start using geometrical shapes like cylinders you introduce what we call "projection error" which can give you erroroneous results as to the intended application. check the minor dia. with gage pins and the threads with threaded plug gages. also- be cognizant of your tolerances. look at your standard deviation or form also.sigpic
Southern Man don't need him around anyhow!
I am having a blast learning to use this system. Some of my students took their reports away with long faces, lotsa red marks...
For english threads the designation will look something like 1/4-20 UNC-2B. The 1/4 is the major diameter of the thread. The 20 means 20 threads/inch. So, to get the pitch (inches/thread) of the thread you invert the fraction and get 1inch/20threads = .05. The UNC is for Unified National Coarse thread. The 2 is a tolerance class. The B designates that it is an internal thread (A is for external).
Now metric threads are designated a little different. Take for example, a M22X1.5 - 6h thread. The M is for metric, the 22 is the major diameter in millimeters. 1.5 IS the pitch in mm/thread. No math required - unless you are writing your program in english and then you will have to divide 1.5mm/thread by 25.4mm/inch to get .059055inches/thread. The 6 is a tolerance class designation. The h is also a tolerance class designation. The fact that the h is lower case means it is an external thread (capital means internal).
All of that is in Machinery's Handbook.Last edited by #2#; 05-15-2007, 05:02 PM.
Originally posted by ajgepper View PostI run V3.5mr2 and do not see height, only depth on my cylinder auto feature screen. Does the auto feature program "force" the programer to use the on clearance planes option? It does not seem to want to work when I step in to measure a hole or cylinder. Anyway, I manually measured two level with 5 hits each and the software recognized a cone. It is still not a very precise position, though.
I'm not sure about 3.5 (I'm using 3.7) but on mine the box for depth is kind of centered in the window just under number of hits. The box for height is over on the right where you choose whether it is an internal (hole) or an external (stud) feature. See this for a good explaination for how to use the two boxes.Last edited by #2#; 05-15-2007, 05:03 PM.
by phillie188Hi,
My question is if measuring a side threaded cylinder (hole) what is the most acurate way? I have always use 3 circles at different...-
07-25-2013, 01:58 PM -
by EmilySueI do not have scanning capability. Therefore, from my reading (remember... Search is my friend) I can still get positions on threaded holes by using auto...
01-04-2018, 05:20 PM -
by FAMOUSX1Hello All,
I have been reading up on the correct way to measure a threaded diameter but I am still unclear on what the correct way is to do this....-
04-12-2016, 05:37 PM -
Hello to Everyone,
I am Alexandre and new to the CMM world. I was hoping I could find some answers on the forum. I'm using PC DMIS 2012....-
02-08-2013, 06:46 PM -
by 1CMM4MEI'm at a stumpified condition: No James, it's not alcohol related
I have searched the forums for this answer as I have found not what I really need...
07-21-2009, 08:41 PM -
