how did you make it easy for yourself to help you remember how to best use the Level, Rotate, and Origin? also, when aligning a round part is it a must to rotate for best results?
Utilities Alignment Box
All of my parts come with blueprints that are fully defined with tolerances and datum structures. That being said, I never make my own decisions. Writing a correct program isn't about remembering steps on how to do it.. its about knowing how to interpret the information on the print... and then translate that to PC DMIS's coding language so you output what your customer needs to see.
Do you have a print with datums/any info specific to this part that would help us help you in a more precise way? Do you have a Datum -A- or Datum -B-? Or a defined ZERO point on your print or something?
In general, I could walk you through how to make a plane/circle alignment if you want..?Last edited by DAN_M; 10-30-2020, 10:02 AM.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
- 1 like
Regarding controlling rotation..it is not necessary.
However, if you are doing anything other than measuring some diameter sizes, I HIGHLY SUGGEST that you DO control rotation. ESPECIALLY if you are going to use the alignment as a base alignment and then offset FROM that alignment. In that scenario, things WILL go bad if you don't rotationally constrain all six degrees of freedom.
At the beginning of your program while recalling startup alignment, CONSTRUCT a LINE, select "ALIGNMENT" in the dropdown box that appears, then press OK. The line will now be in your edit window. I overrode the vector of the line to be X+ (1,0,0) for this example, put it however you need it to be to suit your example. Use this line for rotation as shown. If you F9 my alignment, the trihedron isn't wiggling around like yours would be (meaning all 6 DOF are constrained to PC DMIS).
Code:LIN_XP =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<-0.5,0,0>,<1,0,0> ACTL/<-0.5,0,0>,<1,0,0> CONSTR/LINE,ALIGN,1,XPLUS PLN1 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<9.4567,-0.8591,2.2292>,<0,0,1> ACTL/<9.4567,-0.8591,2.2292>,<0,0,1> TARG/<9.4567,-0.8591,2.2292>,<0,0,1> ANGLE VEC=<1,0,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<8.6702,-0.237,0.601>,<0,0,1>,2.7557 ACTL/<8.6702,-0.237,0.601>,<0,0,1>,2.7557 TARG/<8.6702,-0.237,0.601>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<0.9961947,0,-0.0871557> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO A9 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_XP,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,CIR2 ALIGNMENT/TRANS,YAXIS,CIR2 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/END
Last edited by DAN_M; 10-30-2020, 09:52 AM.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
I don't have Datums. from the print i am using item 1, machine surface as YPLUS. and putting READ POINT in the center of Item 3.
to stat a alignment using Item 1 as plan YPLUS, Item 3 X,Z origin.
Q: when using a read point; do i need a alignment to still teach the machine to the part and and a another alignment for measurements?
notice the trihedron is at the top of the part. that's how it came. i like it in the center of Item 3. part is sitting upright on the plate on a fixture as the picture shows. the trihedron in the picture is exactly how its sitting on the machine. hope that makes sense.
Read point question--> Oh heck yes. The read point, once made into an XYZ alignment, is saying to PC DMIS "that this active probe position is X0Y0Z0". This just gets you started. Its up to you to program in the rest (find the part for real using CNC touches, then create an alignment you want to use, then measure the part).
Translating your trihedron when you have an assembly of CAD stuff in PC DMIS--> Edit/Graphic Display Window/CAD Assembly. Right click on the item in the design tree you want to move, select "Transform" from the dropdown box. Once the "Transformation Dialogue Box" appears, use this window to translate and/or rotate this particular item of your CAD assembly. I use a CMM that has a grid plate, I use external alignments and program with all the CAD just like you. I always import my grid plate and then TRANSLATE it so the trihedron is at the Y-X- corner. Then I put my CAD on top of it where it should be (where it will ultimately be on the CMM in real life). I would then create a program that recalls an external alignment that is tied to my fixture plate, go straight into DCC mode, measure the plane and then the circle, then make a fully defined XYZ alignment used he above referenced methodologyLast edited by DAN_M; 10-30-2020, 10:32 AM.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
Here is a part I am working on now with the code (part pic itself has been suppressed for confidentiality reasons but I can show you the fixture and the beginning of my code)
Code:WORKPLANE/YMINUS MODE/DCC RECALL/ALIGNMENT,EXTERNAL,7107_PLATE_ALIGN LIN_THEO_XP_POS1=FEAT/LINE,CARTESIAN,UNBOUNDED,YES THEO/<-0.5,0,0>,<1,0,0> ACTL/<-0.5,0,0>,<1,0,0> CONSTR/LINE,ALIGN,1,XPLUS LIN_THEO_YP_POS1=FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,-0.5,0>,<0,1,0> ACTL/<0,-0.5,0>,<0,1,0> CONSTR/LINE,ALIGN,1,YPLUS PNT_ORI_PLATE_POS1=FEAT/POINT,CARTESIAN,NO THEO/<0,0,0>,<0,-1,0> ACTL/<0,0,0>,<0,-1,0> CONSTR/POINT,ORIGIN RP_CHECKZ_POS1=FEAT/POINT,CARTESIAN THEO/<0*1,0*1,22*1>,<0,-1,0> ACTL/<0,0,22>,<0,-1,0> READPOINT/ MOVE/INCREMENT,<0,0,22-RP_CHECKZ_POS1.Z> CLEARP/YMINUS,10,YMINUS,10,ON PLN_Y1_POS1=FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<15.3942,11.6159,9.6643>,<0,-1,0> ACTL/<15.3942,11.6159,9.6643>,<0,-1,0> MEAS/PLANE,3 MOVE/CLEARPLANE HIT/BASIC,NORMAL,<15.6065,11.6159,11.1021>,<0,-1,0>,<15.1644,11.6159,11.0744>,USE THEO=YES HIT/BASIC,NORMAL,<16.6631,11.6159,9.6874>,<0,-1,0>,<16.1642,11.6159,9.6097>,USE THEO=YES HIT/BASIC,NORMAL,<13.9129,11.6159,8.2035>,<0,-1,0>,<13.403,11.6159,8.2133>,USE THEO=YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:7107_PLATE_ALIGN,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_Y1_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_THEO_XP_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,PNT_ORI_PLATE_POS1 ALIGNMENT/TRANS,YAXIS,PLN_Y1_POS1 ALIGNMENT/TRANS,ZAXIS,PNT_ORI_PLATE_POS1 ALIGNMENT/END CLEARP/YMINUS,PLN_Y1_POS1.Y-1,YMINUS,PLN_Y1_POS1.Y-1,ON MOVE/CLEARPLANE CIRXZ1_POS1=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<14.9452,0.12,9.4526>,<0,-1,0>,2.7557 ACTL/<14.9452,0.12,9.4526>,<0,-1,0>,2.7557 TARG/<14.9452,0.12,9.4526>,<0,-1,0> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/TRANS,XAXIS,CIRXZ1_POS1 ALIGNMENT/TRANS,ZAXIS,CIRXZ1_POS1 ALIGNMENT/END CIRXZ2_POS1=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<0,0.12,0>,<0,-1,0>,2.7557 ACTL/<0,0.12,0>,<0,-1,0>,2.7557 TARG/<0,0.12,0>,<0,-1,0> START ANG=-120,END ANG=240 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_Y1_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_THEO_XP_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CIRXZ2_POS1 ALIGNMENT/TRANS,YAXIS,PLN_Y1_POS1 ALIGNMENT/TRANS,ZAXIS,CIRXZ2_POS1 ALIGNMENT/END MOVE/CLEARPLANE CIRXZ3_POS1=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<2.5048,0.12,2.3724>,<0,-1,0>,2.9526 ACTL/<2.5048,0.12,2.3724>,<0,-1,0>,2.9526 TARG/<2.5048,0.12,2.3724>,<0,-1,0> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO LIN_ROUGH_XZ_CLK_POS1=FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,0.12,0>,<1,0,0> ACTL/<0,0.12,0>,<1,0,0> CONSTR/LINE,OFFSET SURFACE NORMAL = <0,-1,0>,MULTI POINT ID = CIRXZ2_POS1,CIRXZ3_POS1,, OFFSET = 0,-2.3724 A4 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_Y1_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_ROUGH_XZ_CLK_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CIRXZ2_POS1 ALIGNMENT/TRANS,YAXIS,PLN_Y1_POS1 ALIGNMENT/TRANS,ZAXIS,CIRXZ2_POS1 ALIGNMENT/END GRP_PNTS_PLN_A_POS1=GROUP/SHOWALLPARAMS=NO ENDGROUP/ID=GRP_PNTS_PLN_A_POS1 PLN_A_POS1 =FEAT/PLANE,CARTESIAN,TRIANGLE,YES,LEAST_SQR THEO/<-2.5296,0.8591,2.6412>,<0,-1,0> ACTL/<-2.5296,0.8591,2.6412>,<0,-1,0> CONSTR/PLANE,BF,PNTA1_POS1,PNTA2_POS1,PNTA3_POS1,PNTA4_PO S1,PNTA5_POS1,PNTA6_POS1,PNTA7_POS1,PNTA8_POS1,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 A5 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_A_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_ROUGH_XZ_CLK_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CIRXZ2_POS1 ALIGNMENT/TRANS,YAXIS,PLN_A_POS1 ALIGNMENT/TRANS,ZAXIS,CIRXZ2_POS1 ALIGNMENT/END CLEARP/YMINUS,PLN_A_POS1.Y-1.75,YMINUS,PLN_A_POS1.Y-1.75,ON MOVE/CLEARPLANE CYL_B_POS1 =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<3.2048,0.2756,-0.8276>,<0,-1,0>,0.3143,-0.2559 ACTL/<3.2048,0.2756,-0.8276>,<0,-1,0>,0.3143,-0.2559 TARG/<3.2048,0.2756,-0.8276>,<0,-1,0> START ANG=0,END ANG=360 ANGLE VEC=<-1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PNT_B_POS1 =FEAT/POINT,CARTESIAN,NO THEO/<3.2048,0.2756,-0.8276>,<0,-1,0> ACTL/<3.2048,0.2756,-0.8276>,<0,-1,0> CONSTR/POINT,CAST,CYL_B_POS1 A6 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_A_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_ROUGH_XZ_CLK_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CYL_B_POS1 ALIGNMENT/TRANS,YAXIS,PLN_A_POS1 ALIGNMENT/TRANS,ZAXIS,CYL_B_POS1 ALIGNMENT/END MOVE/CLEARPLANE CYL_C_POS1 =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<-11.9,0.0197,4.1>,<0,1,0>,0.3143,-0.7068 ACTL/<-11.9,0.0197,4.1>,<0,1,0>,0.3143,-0.7068 TARG/<-11.9,0.0197,4.1>,<0,1,0> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PNT_C_POS1 =FEAT/POINT,CARTESIAN,NO THEO/<-11.9,0.0197,4.1>,<0,1,0> ACTL/<-11.9,0.0197,4.1>,<0,1,0> CONSTR/POINT,CAST,CYL_C_POS1 ALI_AB_POS1=ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_A_POS1 ALIGNMENT/ROTATE,XPLUS,TO,LIN_THEO_XP_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CYL_B_POS1 ALIGNMENT/TRANS,YAXIS,PLN_A_POS1 ALIGNMENT/TRANS,ZAXIS,CYL_B_POS1 ALIGNMENT/END LIN_ABC_POS1=FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0,0.1476,0>,<-1,0,0> ACTL/<0,0.1476,0>,<-1,0,0> CONSTR/LINE,OFFSET SURFACE NORMAL = <0,-1,0>,MULTI POINT ID = PNT_B_POS1,PNT_C_POS1,, OFFSET = 0,4.1 ALI_ABC_POS1=ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,YMINUS,PLN_A_POS1 ALIGNMENT/ROTATE,XMINUS,TO,LIN_ABC_POS1,ABOUT,YMINUS ALIGNMENT/TRANS,XAXIS,CYL_B_POS1 ALIGNMENT/TRANS,YAXIS,PLN_A_POS1 ALIGNMENT/TRANS,ZAXIS,CYL_B_POS1 ALIGNMENT/END
Last edited by DAN_M; 10-30-2020, 10:39 AM.SF7107(PCD), SF454(PCD), 152614(Quindos), 9159(Quindos), 7107(Quindos), B&S Manual, M&M Gear Checker
by CubsFan34So I'm trying to create a program using the datums in the attached picture. How do I go about doing this properly. On this fixture Datum A is two different...
03-20-2019, 11:28 AM -
Ok need a little guidance here. I have a part that has it's usual ABC alignment and then other structures beyond that. The problem I am runnin into is...
06-05-2008, 12:38 AM -
by 6819qaHello everybody a quick question , if the Feature control frame show you datum A,B,C in that order, what datum you would use for alignment of the part...
10-14-2015, 12:30 PM -
by d.evansprint attached.
This will probably seem awfully elementary to most of you here, but this is messing with me head.
The primary...-
09-06-2007, 12:44 PM -
by TCeckelsSometimes I tend to get hung up on semantics and I'm pretty sure that this print has me overthinking things again, but I'd still love to have some opinions...
03-28-2008, 08:56 AM -
