Inserting a Move Point Into An Auto Circle
  • Inserting a Move Point Into An Auto Circle
    I have a cylindrical part that requires me to perform a wrist change in the middle of an OD circle measurement. The best setup to get all the other dimensions turns the centerline of the cylinder along the x datum. The part is long and skinny, with bulbous ends, and the OD is between them. I would like to use an auto circle to control the hits better. I have a need to control the circle with the first hit being at Y0 beneath the part. Is it possible to insert a move point say, halfway through (when the probe sphere is above the part) that will allow me to raise the probe up, do a wrist change to A90B180, move to clear point, and continue the auto circle where I left off?
    You can create two separate auto-circles to measure the two "sections" (with the move and wrist change between them) and then build a constructed circle from the two partial autos.
      You can do this in Measured circles. I am not a huge fan of doing it this way though. If it was me I would just create points and construct a circle
      CIR2 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR
      THEO/<0,0,0>,<0,0,1>,1,0
      ACTL/<0,0,0>,<0,0,1>,1,0
      MEAS/CIRCLE,5,ZPLUS
      HIT/BASIC,NORMAL,<0.5,0,0>,<1,0,0>,<0.5,0,0>,USE THEO=YES
      MOVE/CIRCULAR
      HIT/BASIC,NORMAL,<0.1545,0.4755,0>,<0.309017,0.9510565 ,0>,<0.1545,0.4755,0>,USE THEO=YES
      MOVE/CIRCULAR
      HIT/BASIC,NORMAL,<-0.4045,0.2939,0>,<-0.809017,0.5877853,0>,<-0.4045,0.2939,0>,USE THEO=YES
      [B]MOVE/CLEARPLANE
      TIP/T1A90B90, SHANKIJK=-1, 0, 0, ANGLE=90
      MOVE/CLEARPLANE[/B]
      HIT/BASIC,NORMAL,<-0.4045,-0.2939,0>,<-0.809017,-0.5877853,0>,<-0.4045,-0.2939,0>,USE THEO=YES
      MOVE/CIRCULAR
      HIT/BASIC,NORMAL,<0.1545,-0.4755,0>,<0.309017,-0.9510565,0>,<0.1545,-0.4755,0>,USE THEO=YES
      ENDMEAS/
        You can insert move points into an auto circle once it is created. Create the circle. Make sure the crash now, I mean measure now button is turned off. Highlight SHOWHITS and turn to yes. Place your cursor at the end of the line of the last hit you want taken before your clearance moves. Hit "control' M and key in the data. Continue until you have all the clearance moves you want.
        You may need to adjust hit targets on the auto circle prior to creating it if there are areas that you won't be able to probe.
        7107 Global Classic TP20
        2019R1 SP1 CAD++
        • RIDER
          RIDER commented
          Scott D. Haselden I just tried and got the same results that you are getting. It will not allow a tip angle change inside the auto feature.
          If you have to change the tip angle, then you can copy the data from the auto circle hit targets and turn them into vector points. Then delete the auto circle and construct a circle out of the vector points.
        • Scott D. Haselden
          Scott D. Haselden commented
          That worked. Thanks.
        • LaserJay
          LaserJay commented
          Yeah, I really believe that creating points then creating a constructed feature is the way to go
      • Ken8282
        Plane construction
        by Ken8282
        What are your thoughs on putting move points and probe angle changes into the code to construct a plane? Will it cause problem or is it ok to do?
        01-31-2013, 07:09 AM
      • Heming
        Accuracy of measuring holes
        by Heming
        I measured two holes (cyliners) with a 1mmx200 tip at A90B-90. The results are smaller ( couple of thousandth) than the true size measured by hard gage....
        06-12-2009, 09:14 AM
      • Gstuver
        GDT of Slots
        by Gstuver
        Hello Friends, I'm having difficulty with some GDT location for slots. I'm sure this is ignorance on my part. I've attached both the program and the graphics....
        02-20-2018, 03:17 PM
      • justinthorne76
        Program issues
        by justinthorne76
        Having some problems with a program created by someone else. Ive stared at it a few hours and cant figure out what exactly is going on with it. Here is...
        02-05-2016, 11:20 AM
      • Tinyfxds
        Measure Multiple Parts on Fixture
        by Tinyfxds
        I have ten parts mounted in a row on a fixture. I want to pick up the first part, print my report, and then move to the next part using a new alignment...
        07-09-2019, 04:58 PM
