2020 r1 sp7
  • 2020 r1 sp7
    here :
    https://www.wilcoxassoc.com/public/P...20_R1/SP7/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP7/x64/
    Release Notes - 2020 R1
    SP7
    • PCD-178506 - Fixed an issue where the alignment on the slave arm was not
    restored correctly if the execution of a measurement routine on a dual arm
    system was interrupted.
    • PCD-187629 - Fixed an issue where the paste operation didn't work properly
    when you copied the measurement sequence from one measurement routine
    into another.
    • PCD-198325 - Fixed a software crash that occurred when you created a circle
    with the use of a Quick Feature gesture.
    • PCD-198560 - Fixed an issue where the first tip calibration didn't register
    when you indicated that the tool has moved and elected to use the Probe
    Collision Check for the calibration process.
    • PCD-198971 - Fixed an issue where the CWS Thickness Scan didn't work
    with the feature-based measurement.
    • PCD-200143 - Fixed a software crash that occurred when you changed the hit
    target direction in the Live View for the 2D profile.
    • PCD-200174 - Fixed an issue where the section cut profiles and feature
    vectors for ESF (VWMP) features were not drawn when you pressed F9 in the
    Graphic Display window.
    • PCD-200640 - Fixed the HP-TM components issue which included updating
    the nomenclature from HP-TM2 to HP-TMe, and ensured the compatibility
    with the Samara rack (HP-MP).
    • PCD-201006 - Fixed a hardware crash that occurred when you selected the
    Move Feature to Reference Plane check box and performed the calibration
    of an HR-MP rack.
    • PCD-201077 - Fixed an issue where auto calibrate didn't work when a
    machine was in Manual mode which caused PC-DMIS to report collisions that
    did not exist.
    • PCD-201365 - Fixed a software crash that occurred when the HMV debug
    files were closely investigated.
    • PCD-201520 - Fixed an issue with I++ interface where the CMM used the
    move speed from the previous measurement routine unless you changed the
    tool.
    • PCD-201561 - Fixed an issue where PC-DMIS would hang when you
    generated a PPAP report.
    • PCD-201611 - Fixed a software crash that occurred during the optical
    calibration when you selected <Current> from the Illumination list in the
    Calibrate Optics dialog box.
    • PCD-201813 - Fixed an issue where a laser scanner would disconnect
    automatically when you changed the face and one or more scanner LEDs
    were covered.
    • PCD-201970 - Fixed a software crash that occurred when you imported the
    NX part file from the File | Direct CAD Interfaces | NX menu item.
    • PCD-202099 - Fixed an issue where the CAD model views indicated the
    incorrect presence of the GD&T features when PC-DMIS added the icons
    next to the views without PMI.
    • PCD-202892 - Fixed a software crash that occurred when you closed the
    Extended Sheet Metal Features dialog box after you created the Contact
    feature.
    • PCD-203293 - Fixed an issue where the Report Output check box was
    automatically deselected in the Output Configuration dialog box when you
    clicked the Print Full Report button in the marked sets window.
