https://www.wilcoxassoc.com/public/P...20_R2/SP1/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Versions/Release/2020_R2/SP1/x64/
Release Notes - 2020 R2
SP1
• PCD-164339 - Fixed an issue where both perpendicularity and parallelism
showed an incorrect color representation of the size deviation graphic colors.
• PCD-178003 - Fixed an issue where the Probe and Probe Trigger Options
tab were not visible in the Parameter Settings dialog box when you edited
the AutoTrigger command.
• PCD-178506 - Fixed an issue where the alignment on the slave arm was not
restored correctly if the execution of a measurement routine on a dual arm
system was interrupted.
• PCD-186811 - Fixed an issue where the Use datums check box in the legacy
Position dialog box was turned on for all dimensions when you selected the
Use datums check box for only a single dimension.
• PCD-190871 - Fixed an issue where the bookmarks were lost or moved to
another location after the execution of a measurement routine that contained
ESF (VWMP) features.
• PCD-191254 - Fixed a software crash that occurred when you opened the
Constructed Plane dialog box and selected Primary Datum from the list.
• PCD-194568 - Fixed an issue where PC-DMIS automatically deselects the
last selected feature when you clicked in the white area of the Alignment
dialog box.
• PCD-195912 - Fixed an issue where PC-DMIS created a mismatch on the
math applied to the inner circles and outer circles when you selected the Best
Fit Math Type list in the Auto Feature dialog box.
• PCD-195962 - Fixed a software crash that occurred when you worked on a
laser scan in Dual Arm mode.
• PCD-196204 - Fixed an issue where the ESF (VWMP) features selection on
CAD data didn't work when there was a pointcloud data over the CAD model.
• PCD-196697 - Fixed an issue where PC-DMIS didn't position a leader line
correctly for the dimension information.
• PCD-197497 - Fixed an issue where the ESF references were lost in
dimension commands when you opened a measurement routine through a
specific automation method.
• PCD-197924 - Fixed an issue where the Laser extraction results were
inaccurate when you migrated from an older version of PC-DMIS to a newer
version.
• PCD-198325 - Fixed a software crash that occurred when you created a circle
with the use of a Quick Feature gesture.
• PCD-198560 - Fixed an issue where the first tip calibration didn't register
when you indicated that the tool has moved and elected to use the Probe
Collision Check for the calibration process.
• PCD-198971 - Fixed an issue where the CWS Thickness Scan didn't work
with the feature-based measurement.
• PCD-199556 - Fixed an issue where PC-DMIS required two clicks to select a
feature when you selected a surface with a different orientation.
• PCD-199732 - Fixed an issue where the Size dialog box didn't show icons for
the width features.
• PCD-199946 - Updated a DLL to help fix a software crash that occurred when
you closed a measurement routine.
• PCD-200143 - Fixed a software crash that occurred when you changed the hit
target direction in the Live View for the 2D profile.
• PCD-200174 - Fixed an issue where the section cut profiles and feature
vectors for ESF (VWMP) features were not drawn when you pressed F9 in the
Graphic Display window.
• PCD-200245 - Fixed an issue where multiple features showed the same
deviation in the graphical report.
• PCD-200319 - Fixed an issue where you were not able to change the
tolerance type when two or more segments were already available in the
Geometric Tolerance dialog box.
• PCD-202626 - Fixed an issue where PC-DMIS was not able to send the ESF
(VWMP) results to the stats output file.
• PCD-200640 - Fixed the HP-TM components issue which included updating
the nomenclature from HP-TM2 to HP-TMe, and ensured the compatibility
with the Samara rack (HP-MP).
• PCD-200643 - Fixed an issue where PC-DMIS wouldn't set the Stripe
Distance and Exposure values in the Linear Open Scan dialog box and Edit
window for the Eagle Eye sensor.
• PCD-200657 - Fixed an issue where PC-DMIS opened multiple Datum
Definition dialog boxes when you clicked the add button in the Feature
Control Frame tab of the Geometric Tolerance dialog box.
• PCD-200659 - Fixed an issue where the Reorder Selected Items option in
the Geometric Tolerance dialog box didn't work properly when you removed
any items from the selected items list.
• PCD-200675 - Fixed a software crash that occurred when you inserted the
Use Parameter Set/DEFAULT command in the measurement routine.
• PCD-200682 - Fixed an issue where PC-DMIS didn't update the report label
when the SIZE[value] text was removed from the Edit window or from the
• PCD-200694 - Fixed an automation issue where PC-DMIS was not able to
activate the Use COP check box in the Linear Open Scan dialog box.
• PCD-200755 - Fixed an issue where PC-DMIS didn't show the correct
translation for the Dimension ID in the Chinese Traditional and Chinese
Simplified languages after migration of the Geometric Tolerance command.
• PCD-200812 - Fixed a software crash that occurred when you add angles to
the CMS probe and selected From CAD from the New Angles list in the Add
Angles dialog box.
• PCD-200826 - Fixed an issue where the custom probe builder connections
were offset to the edge.
• PCD-200877 - Fixed an issue where the incorrect polar axis and clocking
vector were setup for the Geometric Tolerance position to calculate the polar
angle.
• PCD-200984 - Fixed an issue where PC-DMIS would hang when you created
a POINTINFO command.
• PCD-201006 - Fixed a hardware crash that occurred when you selected the
Move Feature to Reference Plane check box and performed the calibration
of an HR-MP rack.
• PCD-201077 - Fixed an issue where auto calibrate didn't work when a
machine was in Manual mode which caused PC-DMIS to report collisions that
did not exist.
• PCD-201302 - Fixed an issue where PC-DMIS Home page couldn't display
the News feed on the upper-right corner of the page.
• PCD-201365 - Fixed a software crash that occurred when the HMV debug
files were closely investigated.
• PCD-201520 - Fixed an issue with I++ interface where the CMM used the
move speed from the previous measurement routine unless you changed the
tool.
• PCD-201561 - Fixed an issue where PC-DMIS would hang when you
generated a PPAP report.
• PCD-201611 - Fixed a software crash that occurred during the optical
calibration when you selected <Current> from the Illumination list in the
Calibrate Optics dialog box.
• PCD-201649 - Fixed an issue where PC-DMIS showed an error message for
the Geometric Tolerance commands when you used the printed PDF report.
• PCD-201813 - Fixed an issue where a laser scanner would disconnect
automatically when you changed the face and one or more scanner LEDs
were covered.
• PCD-201939 - Fixed an issue where the Geometric Tolerance labels were
missing from the Reporting folder of the installation location.
• PCD-201970 - Fixed a software crash that occurred when you imported the
NX part file from the File | Direct CAD Interfaces | NX menu item.
• PCD-201985 - Fixed an issue where the angle dimension between the two
planes was incorrectly taken as the dimension between the plane and axis.
• PCD-202073 - Fixed an issue where PC-DMIS reported the incorrect size of
the square slot when you measured the square slot as an ESF (VWMP)
feature.
• PCD-202099 - Fixed an issue where the CAD model views indicated the
incorrect presence of the GD&T features when PC-DMIS added the icons
next to the views without PMI.
• PCD-202105 - Fixed an issue where PC-DMIS disabled the Segment Type
toggle when there was more than one segment available in the Geometric
• PCD-202191 - Fixed an issue where the geometric tolerance labels were not
updated in the PPAP report.
• PCD-202247 - Fixed a software crash that occurred when the Xact Measure
features created in versions before 2020 R2 were not able to migrate to the
new Geometric Tolerance.
• PCD-202461 - Added the migration option (.json file) to change the GD&T
standard from the XactMeasure Custom to the Geometric Tolerance ASME or
ISO.
• PCD-202526 - Added Primary Datum support for the two-dimensional circles,
lines, and width features for geometric tolerances with a warning message.
• PCD-202626 - Fixed an issue where PC-DMIS were not able to sent the ESF
• PCD-202675 - Fixed an issue where the geometric tolerance command was
probe-compensated incorrectly for the Auto Line feature on portable
machines.
• PCD-202819 - Fixed a translation issue where you were not able to use
Geometric Tolerance Auto feature Adaptive scanning strategy as the
considered feature for Form and Runout when you ran PC-DMIS in nonEnglish languages.
• PCD-202892 - Fixed a software crash that occurred when you closed the
Extended Sheet Metal Features dialog box after you created the Contact
feature
SP1
dialog box.
version.
the width features.
Angles dialog box.
angle.
of an HR-MP rack.
did not exist.
tool.
were covered.
feature.
ISO.
machines.
feature
